Go to Post Cosmic background radiation is not an approved bumper material. - Nate Laverdure [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
  #46   Spotlight this post!
Unread 07-01-2007, 20:21
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
Re: Robot ideas
You will definitely be seeing a lot of ramp bots. However you have to make sure it is not permanently down, because there is a no wedge rule.
ramps are easy, 179's doing something different, most likely
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
  #47   Spotlight this post!
Unread 07-01-2007, 20:39
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
Re: Robot ideas
well is there any other way to get a bot off the ground besides the ramp(or lifting it)???
  #48   Spotlight this post!
Unread 07-01-2007, 20:40
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Robot ideas
Thusters.
jk about that btw
  #49   Spotlight this post!
Unread 07-01-2007, 20:54
KDawg's Avatar
KDawg KDawg is offline
"That's not a question"
AKA: Kenny Miller
FRC #1126 (SparX)
KDawg will become famous soon enough
Send a message via AIM to KDawg
Re: Robot ideas
I think that yes, we will see some ramp bots, because the lifting at the end is verry crucial; equivelant to about getting a row of 5. Lifting 2 robots a foot would double that, which is 60 points. I think that lifting is a vveerryy crucial task for a team to be able to complete.
1126 TEAM SPARX!!
I am the software team
  #50   Spotlight this post!
Unread 07-01-2007, 21:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Robot ideas
Originally Posted by arbershametaj View Post
3. A powerful robot at the end of the match would prove the difference between no bonus points and 10 bonus points, and hey if all three of the opposite alliance is caught that’s 30 points
If your robot is FORCED to be in the opponents end zone at the end of the match, the 10pt penalty is not applied.
  #51   Spotlight this post!
Unread 07-01-2007, 21:15
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Robot ideas
I do have a question for you all.. If everyone seems to be thinking along the lines of ramps, does this mean noone will build a robot that is a little higher off the ground then most competetions, I mean it doesnt need to be huge off the ground but enough for another robot ( say with a lifting mechenism) to get underneath you to lift you up. Cause out of anything thoughts from me I would see it being easier to have your robot 4 inchs off the ground have someone drive there mechenism under you and you lift your wheels. Just some thoughts!
  #52   Spotlight this post!
Unread 07-01-2007, 21:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot ideas
Look at it this way....it takes a lot of work to lift a 130 lb robot twelve inches, or even four inches. The lifting mechanism would have to be powerful, the structure would have to be strong, and also compensate for the balance problem (lifting one robot next to another one will cause the lifting robot to tip, unless it has some type of outrigger to stabilize it). Since all the robots already have a relatively powerful drive system, why not take advantage of it, and let the other robot drive up yours, using the other one's already available power system? Deploying a ramp takes little work.
I'd be really surprised to see more than a handful of robots that try to lift another one.
  #53   Spotlight this post!
Unread 07-01-2007, 21:33
trilogism
Posts: n/a
Re: Robot ideas
Originally Posted by royalfire View Post
Probably not, but we're not sure. Those who put serious thought into it suggested inflatable ramps, but I think someone said that wasn't allowed. It's probably infeasible, but it'd be hilarious -and moderately effective- if it's allowed. This was partly in response to our programmers' gripes about the camera code. It's our second year, and we went all low-goal last year due to newbie programmers.
The rules say that when the robot is in the home zone, it can be any size it wants as long as it remains in the home zone. So you could make a 26' horizontal arm that entirely blocks off the opposin teams 9 ringers, which would seriously deter their point scoring ability, being limited to half their ringers.
Edit: See rule R12
  #54   Spotlight this post!
Unread 07-01-2007, 22:21
FRC #1360
Re: Robot ideas
True enough, but do remember it only needs to be 4 inchs... minimum that is.. so it doesnt need to be a huge lift, its a fairly small one anyways, making somehting that has a similar design to anything weight lifting construction machine would work wonderful. Those things can lift Waaaaaayyyyy more than they weigh with no problem up to great heights even, I'm personally not going to rule lifting out just yet lol
  #55   Spotlight this post!
Unread 07-01-2007, 22:23
+()c|D's Avatar
+()c|D +()c|D is offline
Go ELEMENT!!
AKA: people call me Todd, I dont know why
FRC #0004 (Element)
+()c|D is an unknown quantity at this point
Send a message via AIM to +()c|D
Re: Robot ideas
Which rule are we looking at???
eace
+()c|D
LA Regional Winner `07
LA Regional Winner `06
  #56   Spotlight this post!
Unread 07-01-2007, 22:24
b-rant's Avatar
b-rant b-rant is offline
AKA: Brantley Brokaw
FRC #0364 (TEAM FUSION!!)
b-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the rough
Send a message via AIM to b-rant
Re: Robot ideas
Four words "The Game of Graces"
  #57   Spotlight this post!
Unread 07-01-2007, 22:25
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Robot ideas
What if they had something to reach over it?
  #58   Spotlight this post!
Unread 07-01-2007, 22:28
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Re: Robot ideas
Then you'd have to make it high.
Team 2522 | Mentor
Formerly of Team 22 and Team 4
  #59   Spotlight this post!
Unread 08-01-2007, 00:15
Jesterofkings's Avatar
Jesterofkings Jesterofkings is offline
FRC #1829 (Fire Bots)
Team Role: Driver
Jesterofkings is an unknown quantity at this point
Send a message via AIM to Jesterofkings Send a message via Yahoo to Jesterofkings
Re: Robot ideas
Our team had the same idea as some others on this post. we were considering making a forklift style capable of lifting ourselves and one other. do you think this idea is plausible? And another question. if our robot is a lifter style and our teammate is flipped do u think it is against the rules to flip our team bak over?
  #60   Spotlight this post!
Unread 08-01-2007, 00:32
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: Robot ideas
haha.. Now your thinking like battlebots... however, i dont know..
Fundraising Ideas chipvalley59 Fundraising 6 08-09-2005 13:58
Any ideas for an "art robot" ninratmny General Forum 11 11-11-2004 20:25
Any ideas for a robot name? Ryan M. Chit-Chat 20 10-02-2004 23:36
Ideas SH_Animation 3D Animation and Competition 9 26-01-2004 16:53
Robot Types (post your ideas here) Rick Rules/Strategy 30 10-02-2002 12:09
