Go to Post Raw students in, pure engineers out. - ebarker [more]
Unread 07-01-2007, 22:18
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Re: Sitting on top of tubes
I thought about the same thing and I put a 40 pound table flat on the tube and then kneeled on it and it did not pop-I weigh 240lbs. Seems silly but it actually worked.
Unread 07-01-2007, 22:28
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Ok, ya, its all about pressure, not weight, so as long as you distribute it evenly you should be just fine with even more weight.
Unread 08-01-2007, 00:14
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Personally, I think game pieces are considered "field elements" and teams will penalized for resting on them.
That said, I do think they should bend the rules a bit and allow creative teams the opportunity to stack a robot on top of the tubes. Though they should assign a penalty if the robot happens to pop them. Making it a fairly risky endeavor, but it would encourage some creativity from teams. Though you've got to consider, the only reason you'd want to do this is so that two robots can climb on top of another robot, and you'd want to support that one robot off the ground. So we're not really talking about whether an inner tube can supporting 120ish pounds of one robot, we're really talking about supporting 360 pounds of 3 robots!
Yeah, I don't think it'll happen. Of course there's also every individual robot climbing onto an inner tube, which would also be an option, though once you get to this pointt would be much easier for teams to just design a decent ramp
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 08-01-2007, 00:25
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Originally Posted by BrianR View Post
When we inflated our tube, we wanted to distribute the weight over the tube, so we put a drafting board on top of it. We didn't have a robot on hand, but we stacked the entire KOP on the board, and it sank to about 6.5" , which is interesting. Has anyone else noticed that they are really only about 7.5" high, not 9.5 like the rulebook claims? So it sank about an inch, although I can't give you a number for how much weight we used. Tomorrow when the weightroom is open we're gonna go try it out with exactly 135 lbs (have to add in bumpers).
Don't forget the battery
Unread 08-01-2007, 00:44
MrShifty's Avatar
MrShifty MrShifty is offline
FRC #1164 (Project NEO)
MrShifty is an unknown quantity at this point
The "climbing on a tube" angle seems to be lawering the rule a bit. The spirit of the rule is clearly to get robots that can stack on top of one-another. I suspect that a revision/clarification to the rules will reflect this.
That said, there was a lot of discussion today about doing that. It would be an interesting mechanism that would allow a robot to climb on a tube without flipping it, popping it, or falling off. Those things are tricky for people to get in (in a pool)...
Unread 08-01-2007, 01:16
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I think the main question is this: does a tube count as a field element? Because as per <G56> ROBOTS in HOME ZONE - ROBOTS score bonus points at the end of the match if they are entirely in their HOME ZONE, not in contact with any element of the field (carpet, alliance station, goal etc.) I think tubes count as field elements, and hence this will not qualify for bonus points.
Unread 08-01-2007, 01:29
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I have already thought of a safe, non-damaging, & effective way (in theory of course.. have to add that in there since nothing was built yet. ) for at least a class 3 (light weight) robot to do this.
I will hold off on releasing this idea if we decide to not do it, cause I would LOVE to see a team try this if it is legal and would gladly give input to a team who wants to take that challenge.
<crosses fingers for legality ruling>
Unread 08-01-2007, 01:46
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Hahaha great minds think alike
I asked Woodie on the Manchester Kick-off and sadly we can't do that for a bonus.
Unread 08-01-2007, 02:03
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
even if they did allow us would be hard considering we have fifteen seconds of the match to do it if not before hand
and plus we cant use multiple tubes to distribute our weight cuz we can only be touching one tube ate a time. saying this statement is point less considering the last 2-3 comments negated this whole conversation
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
pic: Top Gun Top Wheels Rick TYler Robot Showcase 4 04-02-2006 11:13
Top 10! Andy Grady General Forum 144 02-03-2004 18:49
One Robot Sitting on top of another question rkyro22 Rules/Strategy 14 09-01-2003 03:48
Top 5! Andy Grady General Forum 16 06-01-2003 00:20
Both alliances sitting in endzone with 10 seconds left? Mike Soukup General Forum 7 24-03-2002 18:55
