Go to Post Yeah After we decided not to do autonomous, the robot took matters into it's own hand. i'd bet it would get it's self DQ'd... or an award. - GMKlenklen [more]
Unread 07-01-2007, 22:28
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Using two CIMs in the Banebots Transmission
The BaneBots site has the adapter to run two CIM's with the new gearbox...who will be doing that?
Our robot will be 5', 110lbs, probably maxed out on weight. We will be running these gearboxes with two CIM's...we could use the extra torque in case we get into a pushing match.
Unread 07-01-2007, 22:44
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: Who will be doubling up?
My thoughts on that was that for not much extra cost(about $90), you can get much greater reliability by just getting two more gearboxes.
With a relatively untested gearbox, I'd be hesitant to put two cim's through a single one. Two separate gear boxes per side will reduce the strain on the gears in each gearbox and provide at least some power on each side even if a gearbox fails.
Any weight difference between the adapter weight and the gearboxes could probably be made up with less chain use.
Team 675-Alumni
Near Chaos Robotics
Unread 08-01-2007, 02:08
Back after 4 years off
FRC #5279
While the gear box is untested in FIRST is is my understanding that they are quite popular in battle bots and other competitions.
Our team however invested in some AM 2 speeds and I think we will be using them again.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 08-01-2007, 02:28
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Originally Posted by Tri_Lam View Post
uhhh what are cim's ~_~
cims are the 2 suplied black motors that the kit comes, but there is a difference between them and the even larger "mini-bike" motor that has the belt pully and tensioners on it.
Unread 08-01-2007, 02:30
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
thx heh i just called them black motors
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Unread 08-01-2007, 02:32
zander_108's Avatar
AKA: Zander Guerra
ha, its ok, dont sweat it
Unread 08-01-2007, 02:49
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
They are used in Battlebots, in the 12 and 30lb competitions locally. The Banebots gearboxes have performed phenominally in battlebots, but I'd be hesitant to put that much through an essentially over-engineered drill transmission. Buy 2 more and run 2 on each side, factor of saftey will be good.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 08-01-2007, 02:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Using two CIMs in the Banebots Transmission
Okay, so say you've got 5" wheels perfect size to direct drive. 6 of them, 3 per side. What do you do? Buy the double motor kit, direct drive the centers with a single planetary and run chains out to the corners is the most logical thing. But only if "it'll hold." I mean, 4 planetaries with 6 wheels? It's not clean. So, will they hold up with two CIMs in there? Joe Johnson have any input?
Unread 08-01-2007, 14:06
Mechanical/Driver
Hmmm...after some thought I think I just might get two more gearboxes, with a total of 4. The robot design would be for 4WD, so now that I think it would make more sense to have each wheel be powered by it's own independent gearbox/chain geardown. It'll wind up costing us almost double, but worth it. Double the strength and reliability, with the same current requirements as a doubled gearbox.
Back to Autodesk....
Unread 08-01-2007, 23:27
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
The kit sprockets (28 tooth and 16 tooth), give a reduction of 1.75:1 , in addition to the 12:1 , which is around 21:1 ,
5280 no load rpm ---> 251 rpm with the reduction ,. this still seems kind of fast with the standard kit size wheels, are you using other sprockets not provided in the kit ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 08-01-2007, 23:41
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
251 rpm is 4.2 revs per second. With a 6" dia. wheel the circumference is 18.8 inches, giving a theoretical top speed of 6.6 feet per second. (Or 2m/s aka 7.2km/h) With smaller wheels, you'll be slower.
Depending on your team's strategy you might like the pushing power that offers or you might want to move faster. I'm looking at the opportunity for direct drive from the tranny output shaft and a bit more speed.
Someone earlier posted about how best to drive a 6wd chassis with four gearboxes. I'd say direct drive to two axles and chains or belts linking all three axles.
Jason
Unread 09-01-2007, 00:18
Mechanical/Driver
As of now the gearboxes will be run on each independent chain geardown, on each wheel. I haven't decided what size sprockets to run yet; this is going to be one of those things we'll swap out later in testing. I assume I'll start with the stock sizes given in the KOP, then adjust accordingly. Right now our main concern is getting the bot modeled in CAD with the 4 gearboxes so we can get to work on our chassis....sprocket sizes and geardown can be adjusted later, we have tons of extra sprockets lying around.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-01-2007, 08:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
This is an age old design choice. In general, I come down on the chain between the wheels camp rather than independently driving each wheel. It boils down to this: When you are pushing against another robot, your front wheels tend to lift and your back wheels tend to get more weight on them. This means that your front wheels are likely slipping and your back wheels are doing most of the pushing. In the independently driven wheels case, only your back motors are doing any useful pushing. This is not why you wanted 4 motor drive! So... whether you buy 2 planetary gearboxes or buy the adaptor to drive 1 planetary gearbox with 2 CIMs, I highly recommend that you consider having chain link all your wheels (and by the way the right number of drive wheels is 6 -- FYI).
Joe J.
P.S. It is my considered opinion that the Banebot 56mm gearbox is sufficiently over designed for 1 CIM motor that it can easily accept the load of 2 CIMs. In fact, I think it be converted to accept 2 CIMs AND a Fisher Price in case you are in the Team 25 Camp (a.k.a. The 3-Motors-Per-Side-Minimum Camp)
Name:	CIM FISHERPRICE 2CIM 1FP.jpg
Team #88, TJ2
Unread 09-01-2007, 09:32
Mechanical/Driver
Joe J.
Thanks for the tip. I was considering doing that to distrubute pushing power among all the wheels. Just run a chain from the output shaft to the wheels, then attach an additional sprocket to the opposite side of the wheel, and run a chain connecting the two wheels together with the same size sprockets.
Unread 09-01-2007, 09:35
Billfred's Avatar
Billfred Billfred is offline
Can you attach two sprockets to the AndyMark wheels in the kit?
I haven't tried it with these exact wheels, but last year 1293 ran two sprockets off of an IFI wheel in their 6WD setup. You've got to put a little space between the two sprockets through your choice of method (either bolt them on both sides or put a spacer on the bolt holding them on), but it's entirely possible.
pic: DeWalt Gearbox with two CIMs MAteo9944 Extra Discussion 17 02-01-2007 05:34
New CIMs in kit transmission Reyner General Forum 6 15-01-2006 16:59
Problem using two transmitters jamesgecko FIRST Tech Challenge 9 12-05-2005 09:30
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
40A Breakers popping when using CIMs galewind Electrical 9 13-02-2003 10:30
