Go to Post If people played without PDA's back when FIRST had this addiction to nigh-impossible-to-calculate-in-your-head multipliers, then we can play without PDA's now. - Ian Curtis [more]
Unread 06-01-2007, 13:57
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
2007 Motor Specs
This thread is for people to post specs of the 2007 motors.
New motors: the two banebots motors. spec spec spec!
I'm off to work spec-ing them up, will post.
Unread 06-01-2007, 17:26
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 2007 Motor Specs
Banebots RS-540 motor
Nominal v: 12v, No Load RPM: 16800, Stall Current: 42A
Kt: 0.94 oz-in/A, Kv: 1400 rpm/V, Efficiency: 71%
more info here
Motor Specifications
Performance
Operating v : 4.5v - 12v
Nominal v : 12v
No Load RPM : 16800
No Load A : 1A
Stall Torque : 39.48 oz-in 278.8 mN-m
Stall Current : 42A
Kt : 0.94 oz-in/A 6.6 mN-m/A
Kv : 1400 rpm/V
Efficiency : 71%
RPM - Peak Eff : 14525
Current - Peak Eff : 6.6A
Physical
Weight : 5.4 oz (153g)
Length - for motor : 1.97 in (50mm)
Diameter : 1.41 in (35.8mm)
ShaftDiameter : 0.12 in (3.2mm)
Shaft Length : 0.3 in (7.6mm)
Mounting Screws (2) M3
Banebots has added a link on their home page for FIRST teams, which goes straight to the parts included in the KOP.
Unread 07-01-2007, 11:59
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Looking at <R27> in section 8.3.4 leads me to believe that once again we have a different fisher price motor to spec out this year, unless its the same as the one we had two years ago because it says
Originally Posted by 8.3.4<R27>
"Note that the fisher price motor found in the 2007 kit of parts is different from the FP found in the most recent KOP"
If it is the same as 2005 does anyone still have the specs laying around?
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 07-01-2007, 12:09
President, VEX Robotics, Inc.
We are back at it again. It does not look like FIRST has published the FP motor specs this year. I have searched through all my previous posts (back to 2002) and checked all the FP motor specs I have published in the past. This year's motor is different from the 2002, 2003, 2004, 2005, and 2006 motors.
One thing is certain: the motor is made by Johnson Electric. That is good news since I should be able to get the data from JE this week. Our gear on the motor is 19 teeth, but I do not know if everyone's is the same. I will post to this thread when I get the motor data.
Unread 07-01-2007, 12:35
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Does anyone know the motor specs on the Keyang Motor?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 07-01-2007, 21:31
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Are we going to get power/rpm/ current curves on these RS-540 motors as we have in the past with new motors in the kit, or do we have to estimate it ourselves?
Team 1062, The Storm, 2003
Unread 07-01-2007, 21:33
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by Kit Gerhart View Post
Are we going to get power/rpm/ current information on these RS-540 motors as we have in the past with new motors in the kit, or do we have to estimate it ourselves?
I think the information you're looking for is available on the Banebots website.
The gearmotors specs. can be found here: http://www.banebots.com/pc/MP-36XXX-540/MP-36064-540
The motor specs. without the gearbox are here:
http://www.banebots.com/p/M2-RS540-120
They don't have the curves themselves, but there's at least some information available.
--Madison--
...down at the Ozdust!
Unread 07-01-2007, 21:38
There is some info on the banebots site, but not the actual power information I'd like. Of course, if I get a little more ambitious, I can calculate a good approximation of what I'm looking for. I'd like to know the maximum power in watts or horsepower that the motor produces.
Unread 07-01-2007, 23:02
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Power (output) it torque times speed. Well... Watts = N-m * radians/sec. or = N-m * RPM/60*2*pi.
RPM decreases linearly from no load speed at ... no load, to zero at stall. Thus, max power is always at half the no load speed.
Thus, Max power for the RS540 is ~122W.
The RS 545 is 108W.
This is, of course, highly approximate. But you really should be designing below Max power anyways, right?
Unread 08-01-2007, 08:58
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
This is the Fisher-Price 00968-9012, one of the RS-550 Johnson motors allowed (but not supplied to all teams) in 2006. The 9003 (largely equivalent, and also supplied to some teams in 2006) is not legal. FIRST's 2006 spec sheet is here. To identify the number of gear teeth on the motor pinion, without disassembling it, examine the injection-moulded plastic gear housing, and look for a small number 19 (or 16, or 20) on the side. 188 received 19-tooth-compatible gear reducers.
Unread 08-01-2007, 09:15
The RS 545 is 108W.
Thanks for doing the calculation for me. Yes, we design for well below peak power (motor running maybe 75-80 % of no-load rpm) except for an occasional few seconds of "extreme" operation near its power peak. Most of our motors will have a very short service life if run at their power peak.
Unread 09-01-2007, 00:32
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Would it be legal to buy 2 extra 56mm Planetary Gearbox, 12:1? The same one included in the KOP?
Also, how much do these gearboxes weigh?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 09-01-2007, 00:35
Perfectly legal. It's COTS item offered by BaneBots and it costs less than $400. Well. Perfectly legal as long as you still stay under your $3500 limit.
EDIT: I weighed them in at around 2.5 lbs apiece last night. The only scale I had was a bit nutty, so YMMV by +/- .25 lbs.
Unread 09-01-2007, 00:38
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Thanks! Does that weight include the CIM? If not what is the mass of the CIM motors?
Callsign: N6ARA
Unread 09-01-2007, 01:49
Madison's Avatar
FRC #0488 (Xbot)
They're about 2.5 lbs. without the motors. The motors themselves are about another 2.5 lbs. each, as I recall.
--Madison--
Motor Specs??? tenfour General Forum 1 10-01-2003 17:56
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
Chiapua motor specs? Nick Boyajian Motors 2 09-01-2002 06:14
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
