Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 08-01-2007, 05:37
bballbeng bballbeng is offline
bballbeng is an unknown quantity at this point
Unhappy CMU CAM2 image colors looks weird!! urgent help needed
Hi guys...desperately need help on this....my supposingly white color in the image from the camera appears to be yellowish..and the color of my hand appears to be dark dark blue....what is happening to the image?? anyone there pls help!!!
Unread 08-01-2007, 07:06
Re: CMU CAM2 image colors looks weird!! urgent help needed
What application are you using to view the image? The camera has probably been placed in a color mode other than RGB, making colors look very odd on the monitor. (For detecting the green target light, the YCrCb mode is preferred.)
Unread 08-01-2007, 09:44
i am writting an application myself to display the cmu cam 2 image..that means to say the image data output by the send frame command is not in RGB format?? do u know how to convert it to rgb cos in my application...i set each RGB colors of each pixel according to the whole chunk of image data which i supposed it to be in ( r g b r g b r g b .....) as well..
CMU Cam2 Java app (Help with Labview GUI) Team 1649 Programming 3 26-12-2006 14:25
CMU CAM2 won't track! 1594code Programming 2 19-12-2006 22:20
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
URgent Programming Help needed rcubes85 Programming 4 15-02-2005 23:21
Gear Help Needed- Urgent psychoCHIPMUNKK Technical Discussion 6 05-02-2004 13:44
