Go to Post You know you've overdosed on FIRST when you set your alarm clock to your team # ex: 9:32 - bladetech932 [more]
Unread 08-01-2007, 06:41
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: MK 12 volt battery question
Originally Posted by nparikh View Post
Don't know if anyone has noticed this, but the new batteries seem a bit heavier as well. We pulled out the scale today and clocked them at about 13.5lbs, which is about 1.5 lbs more than the old batteries (someone correct me if I'm wrong that the old ones weighed 12lbs)
Based on the spec sheets linked by Richard, the new batteries are only about .4 lbs heavier
The old exides list approx 13.44 lbs while the new MKs list 13.82 lbs
I'm more concerned about the max current draw - like Karthik said, if the draw is that much different than it will definitely have an impact on robot performance and capabilities
Unread 08-01-2007, 08:09
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Karthik View Post
There are some major differences between the two sections of spec sheets you posted. ...
I'd guess that the 90A figure in the top section is an error. The lower section shows 360A maximum discharge current for 30 seconds. Also, the discharge time vs. discharge current curves shown near the bottom indicate several minutes capability at 3C (54A) discharge current; this is similar to the 3C capability of the older battery. It appears the new and old batteries are similarly constructed, and that the new one is designed for slightly (~10%) lower capacity. This may be a design trade-off to allow higher short-duration discharge currents. (A little more lead, a little less acid.)
Richard Wallace
since 2003
Unread 08-01-2007, 08:20
Karthik,
The specifications on the MK site are very close to the specifications for the old battery. The differences are slight enough to merely be differences in testing methods or the influence of the marketing departments. A close inspection of the discharge curves show that they are at slightly different currents from the batteries we have used in the past. A quick interpolation of the data would show them to be almost identical. Let's face it, a battery of the same physical size and chemistry with the same amp hour rating is going to be pretty close in performance. You can only pack so much lead and acid into that package. I hate to have to buy new batteries this year but if those are the rules then so be it.
Unread 08-01-2007, 08:27
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
As I am reading this chart it seems the new battery has a HIGHER discharge rate. 5 seconds @ 720A this years battery and last years battery is 5 seconds @ 230A. Therefore it would better seem the new battery is BETTER for burst and a quick pushing match...
-Mike
Unread 08-01-2007, 08:39
Mike,
Although that specification looks different, last year's battery was capable of the same high current for short periods and when new and fully charged. "Your mileage will vary." In fact most teams will not be able to draw this kind of current simply because there are other limiting factors like the combined resistance of the wiring, breakers, speed controllers and connectors.
Remember that the real test will be how much you can draw over a two+ minute match and remain above 8 volts, the critical cutout for the RC.
Unread 08-01-2007, 09:49
pyrr101's Avatar
pyrr101 pyrr101 is offline
AKA: Travis
FRC #0537 (Charger Robotics)
Team Role: Electrical
pyrr101 is an unknown quantity at this point
Send a message via AIM to pyrr101 Send a message via MSN to pyrr101 Send a message via Yahoo to pyrr101
Reading the label on the battery, this years battery is 18AH instead of last years 17AH.
The R46 rule says the use of batteries different from or in addition to the ones provided, nothing about more then one on a robot.
This can be read as the ones given in the KOP are the only ones to be used on the field.
Team 537 Electrical Lead
Waukesha County Sheriff Department, SWAT 'BOT lead
Wisconsin, Buckeye, and Nationals here we come!
Wisconsin Regional:
  • Rockwell Automation Innovation in Control Award
  • Regional Engineering Inspiration Award
  • Regional Winner
Unread 08-01-2007, 09:57
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
First of all, last year's battery was an Exide ES 18-12 (or the EX 18-12, in some cases), which is the same battery that we have used for many years, and it is indeed an 18AH battery. Many people have linked to the datasheet for this, so you can confirm there.
Also, as stated before, <R53> clearly states that we CAN purchase additional MK batteries for use during the competition. <R46> states that you can not use more than one battery on the robot during a match.
-Nate
Unread 08-01-2007, 10:18
RoboDriver's Avatar
RoboDriver RoboDriver is offline
AKA: ERIC
FRC #0326 (Xtreme Eagles)
RoboDriver will become famous soon enough
You are right but it does not matter because it dose not factor into the weight of the robot.
THINK IT...
DESIGN IT...
BUILD IT...
2008 GREAT LAKES CHAMPS THANKS 67 ,503
Unread 08-01-2007, 11:11
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Thanks for listing the specs for the 2007 battery
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 08-01-2007, 13:02
pyrr101's Avatar
AKA: Travis
Thank you, there are many conflects in the rules.
Wisconsin Regional:
  • Regional Winner
Unread 08-01-2007, 13:48
Erro's Avatar
Erro Erro is offline
Chairman's Team Student Leader
AKA: Will H.
FRC #0365 (Miracle of Engineering)
Erro is an unknown quantity at this point
It appears that the new batteries should not have a great effect on teams. MOE only uses the new batteries in competitions any way, and the old ones are perfectly legal for practice. As always, we're always willing to share with other teams, just let us know you need them
Enthusiastic (and often exasperated ) former captain of MOE 365 Chairman's Award Presentation Team...
Willy the Wandering Turtle (don't ask me where I picked that one up- it's a long story)...
Check out the blog at http://politicalhumorscience.blogspot.com
Unread 08-01-2007, 15:05
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
The 10% difference sited on old vs new battery may or may not exist. The old battery specs its 9Ah at 0C/32F. The new battery specs its 8.1Ah at 25C. Specmanship in play as the temperature of the measurement is important.
The old battery lists 9AH with a 18A (1C) draw at 0C/32F temperature.
It also has a curve for 20C/68F which shows roughly something like ~7.5Ah-8Ah (hard to get exact with the log graph shown but looks like 24+/-2 minutes until 100% depth of discharge (DoD) is reached).
The new battery lists 8.1Ah with 18A (1C) draw at 25C, about 27 minutes to 100% DoD. The actual discharge graph only shows a 17A discharge curve, but it too looks to be in the 28 minute range to 100% DoD.
http://www.rpci-inc.com/pdf/ES17-12.pdf
I overlaid the discharge curves between old/new. The 17A/18A are green/red curves. What is more interesting are the 36A (old) vs 34A (new) curves. The 36A (old) curve shows 100% DoD at about 16-18 minutes vs 34A (new) curve shows 100% DoD at about 9-10 minutes. The voltage drop under load favors the new battery which maintains a much higher voltage output under similar load. This was confirmed by a quickie test using a 50A dummy load on last year's ES18-12 vs this year's ES17-12. The ES17 had a ~.2-.3v higher voltage while under load. Load was held for 20-30 seconds.
The batteries are close, but are different and diverge at larger discharge rates. The biggest difference seems to be the maximum spec'd discharge; 230A (old) vs 720A (new). Greater safety margin?
Bud
Unread 08-01-2007, 21:08
bWard bWard is offline
FRC #1276 (Kaizen Blitz)
bWard is an unknown quantity at this point
Send a message via AIM to bWard
this is the right battery right?
http://store.aiconsol.com/es17-12-mk-battery.html
Unread 08-01-2007, 21:20
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
As an Israeli team we dont have a local seller of hose batteries..
What are we supposed to doif we want more of them?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2007, 21:28
Billfred's Avatar
Billfred Billfred is offline
I'd explore <R25>:
<R25> Teams participating in the 2007 FIRST Robotics Competition that are located outside North America may not be able to acquire the exact part (as identified by specific part numbers) or materials of the specified dimensions as defined in these rules. In such situations, international teams must submit a request for approval of nearest-equivalent parts (e.g. nearest metric equivalent, etc.) to FIRST Headquarters. FIRST will determine suitability of the part. If approved, a confirming e-mail will be sent to the team. The team must bring a copy of the e-mail to any competition event to verify that the use of an alternate part has been approved.
Battery question CraigHickman Electrical 9 23-10-2006 21:55
Extra Battery Question 1337pcgamer General Forum 1 16-02-2006 19:58
Question regarding to Battery Packaging sxlterps General Forum 1 19-02-2005 17:37
7.2 Volt Battery Justin_302 Electrical 4 28-01-2005 23:25
Help!!! Battery question trollin1st General Forum 7 12-02-2003 08:48
