Go to Post Even when the system is "really good" it can always be tweaked a little to make it even better. - dlavery [more]
Unread 07-01-2007, 11:41
foote stepped in
AKA: E. Foote
FRC #0868
Re: Universal Robot Connector
What if instead of making a universal latch, for all teams, wouldn't it be better if the teams that planned on specifically lifting robots to make a set of their own latches? Then they could instruct teams on where to place them. With this in mind, i think each team should make sure that their robot is 1/2 - 1 lb underweight (lol, like that would ever happen), so that if they are paired up with a lifter, then it would be much easier to work within the rules.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 07-01-2007, 11:47
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Originally Posted by Gerb4L View Post
Great idea guys! I have a question though: if a robot were to lift an alliance member by pushing up from below would this still count for the points? I was wondering because you have all seemed to be concentrating on lifting from above. I believe that pushing up from below would greatly simplify the problem.
-Gerb4L
Well our team decided how to lift the robot from the bottom and believe it or not the solution to this is seen at every regional event, as well as in every single car in the united states.
Championship - Delphi "Driving Tomorrows Technology"
Unread 07-01-2007, 11:51
eshteyn's Avatar
Also, there is no need for a latch. If you can make your lifting bot lift the alliance member in a smooth motion then you will not have to have a latch. the weight of the robot will be enough to hold him on you lifting surface, and if anything else the other team can thrust forward in order to keep the robot tight on your lifting plane.
Unread 07-01-2007, 14:09
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
It was easy just after kickoff, with that crazy image from the animation in our minds, to immediately think of a latch. Some kinda ramp may end up being much more versatile, maybe one which raises to horizontal after the robot has driven onto it.
Unread 07-01-2007, 14:25
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Aha! But a ramp that can lift 240lbs? (2x120lb robots in theory)
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 07-01-2007, 16:12
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
-Gerb4L
I agree, lifting from below would be mechanically simpler, since you could get leverage directly off the ground. You need to distribute the lift so the other robot stays ballanced (maybe 3 or 4 lift points).
All the rules say is the the lowest point of the other robot must be 4+ or 12+" off the ground.
Phil Malone
http://www.GEARSinc.org
Unread 07-01-2007, 16:43
mehul mehul is offline
no team (Technotics)
Team Role: Animator
mehul is an unknown quantity at this point
lol i had exact same idea its the simplest and yet it would work with any robot that moves without additional requirements.
Unread 07-01-2007, 22:46
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Originally Posted by PhilBot View Post
Yeah.. USBCD36....
Our team also like the idea of a ramp/platform soultion. Let's fact it, all the bots will have the ability to move... If we could get some standardization on minimal ramp climbing ability/clearance requirements we could get some cool cooperative alliances.
A 4" platform with a short ramp seems more universally achievable than a 12" platform, which would need a much longer ramp for many bots. But, we do have the ability to specify a much more grippy ramp material, so it could be made easier than last year's ramp.
I see a new scouting class distinction here: Are you a Lifter or a Ramper?
I wasn't thinking of it being nearly as steep as the ramps were last year, since most robots with center wheel drive couldn't get up. One of my team members calculated that the simplest ramp to make would have about an 18° slope. Is that reasonable for most 'bots?
Unread 07-01-2007, 23:10
An arm would do better?
Someone just say it so it's out in the thread for discussion.
Unread 08-01-2007, 12:40
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Or even as high as ~300#?
[120# + 13# (battery) + 15# (bumpers)]*2 = 296#
I think we will probably see more ramps than arms...can you imagine a robot trying to lift another robot and seeing it tip over? I'm positive (and hopeful) that teams would think about such a scenario beforehand, but I don't see going through all the trouble when a ramp is easier to build.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 08-01-2007, 15:59
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Way back in '02, we had three goals to play with. each weighed over 200 lbs and there were several robots that would lift two. Of course that was only to transfer the weight to your wheels for traction so we didn't have to go quite so high, but it is doable. It is only a matter of how long you want to take
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Universal Game Winning Robot/Strategy for any year sanddrag Chit-Chat 6 06-04-2006 16:36
UNIVERSAL Emulation? WHAT!?!?! Joe Matt Chit-Chat 5 12-10-2004 12:52
Universal Robot Unvaling Thread Joe Matt General Forum 5 05-01-2003 12:09
90 degree robot modem connector archiver 2001 10 24-06-2002 00:03
Release of Universal Terms... archiver 2001 1 24-06-2002 00:01
