Go to Post The point of outreach isn't to "win" a "game" so I'm not sure what you hope to achieve with such a concept. The idea of "beating" another team in terms of outreach is fundamentally flawed. - dcarr [more]
Unread 08-01-2007, 12:28
1573's Avatar
1573 1573 is offline
FRC #1573 (KGSTARS)
1573 is an unknown quantity at this point
Send a message via ICQ to 1573
Problem with program uploading
i cant upload program with easyCPRO i checked out the cable and tried on other computers but it still dont works can some one help me???
Unread 08-01-2007, 12:51
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
Re: Problem with program uploading
did you press the programe button?
Unread 08-01-2007, 13:09
jesusfreakmths's Avatar
jesusfreakmths jesusfreakmths is offline
AKA: Jonathan
FRC #1778
jesusfreakmths will become famous soon enough
Send a message via AIM to jesusfreakmths
Do you guys know were I can find the code for the camra. Or any info on how to use it, and see code that can give us an idea on how to include it in the code/recive info from it?
Jonathan
Unread 08-01-2007, 15:23
1573's Avatar
FRC #1573 (KGSTARS)
yes i did and the state of the led is always orange (meen i can upload) but it there still an error check out the program state or the cable but every thing is connected.
Unread 08-01-2007, 15:26
Davx's Avatar
Davx Davx is offline
Davux
AKA: Dave Amenta
FRC #0195 (Cyber Knights)
Davx will become famous soon enoughDavx will become famous soon enough
Send a message via AIM to Davx Send a message via MSN to Davx
jesusfreakmths: Check out http://kevin.org/frc for some camera implementation code.
1573: In order to program your robot you will need to press and hold the PROG button on your RC, until two orange LEDs are illuminated. Once this is so, send the code with your laptop, but make sure that you have the correct serial port specified. If you are using a USB-To-Serial adapter, you may need to check which COM port it's mapped to. (Control Panel > System > Hardware > Device Manager > Ports (COM & LPT)).
If you're not sure if your adapter is working or not, connect the serial to the program port, open the IFI loader terminal (make sure the window title says that you're connected properly) and hit the reset button on the RC. You should see an init. string. If not, the problem is in your adapter.
--David Amenta - Dave Amenta .com - Person Meets Profession
Unread 08-01-2007, 15:40
1573's Avatar
FRC #1573 (KGSTARS)
Unhappy Re: Problem with program uploading
no, the problem it all that i cant connect to the RC 2 leds are orange and in the program state but there still an error... and i chacked out the computer and tried on other but there the same problem
Unread 08-01-2007, 15:46
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Try turning off "verify and download" in the loader setup.
Also make sure you have the correct device selected as easyC can program 04/05 & 06/07 & VEX
Demo Camera Code: http://www.intelitekdownloads.com/easyCPRO/
Unread 08-01-2007, 15:50
1573's Avatar
FRC #1573 (KGSTARS)
nope still don't works the download setting is on frc 2006/2007 controler
Unread 08-01-2007, 17:45
intelitek_Chris intelitek_Chris is offline
intelitek_Chris will become famous soon enoughintelitek_Chris will become famous soon enough
easyC does not automatically detect (and can't possibly know) what port you want to use to download. You probably have the wrong COM port selected. Go to the 'loader setup' and try selecting another one of the available ports until you find the right one. If you are using a USB adapter, each time you unplug the cable and insert it again, there is a chance your COM port number will change.
If this doesn't help, try another loader. You can grab the hex file from your project folder and use another loader to upload it to the RC as a test.
Good luck,
Chris
Unread 09-01-2007, 02:59
1573's Avatar
FRC #1573 (KGSTARS)
nope, i dont understand what can be the problem i tried 2 controlers 2007 and 2006 controlers and tried in 2 computers with 2 diffrent loaders one from easyC and the other from MPlab but there still the same problem "To enable download, hold the 'PROG' button down until the 'PROGRAM STATE' LED is solid orange. Make sure that power is on and the serial cable is connected" any one can help me with that??
Unread 09-01-2007, 07:49
Kingofl337's Avatar
AKA: Adam
What are you using for a serial port? USB or Onboard?
Unread 09-01-2007, 08:19
Kawashima Kawashima is offline
FRC #1382 (Etepteam)
Kawashima is an unknown quantity at this point
Press and hold the Reset and Prog buttons, until the battery led solid green, and then release reset butoon. After that, release prog buttons.
uploading!!
Unread 10-01-2007, 02:01
1573's Avatar
FRC #1573 (KGSTARS)
im using the com port on my computer not the usb adapter.
Unread 10-01-2007, 15:13
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
1573,
Can you tell us: what is the error message?
when does the error message occur? (after you press what button?)
What have you selected from the drop-down list of COM ports?
What shows up in the status bar of the window?
Can you post a screenshot of the error?
-- by the way,
Is your "program led" always orange? even before you press the "prog" button?
Good luck!
David A.
Unread 11-01-2007, 03:12
1573's Avatar
FRC #1573 (KGSTARS)
after i press the program state button and the LED is solid orange and i press the donload button. this is the error that i get...
i have tried to do everything but still it doesn't works...
Program Build Problem douglass1371 Programming 3 18-02-2006 18:46
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
program download problem zdeswarte Programming 5 23-03-2005 06:46
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
