Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
Unread 08-01-2007, 16:00
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: adding swiches to O/I
yes yes you can. go download the pin out guide from IFI and that should help you figure out how to make a custom UI.
refrence guide
page 6 should be helpful to you
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 08-01-2007, 16:08
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
The Blue Alliance did an episode on custom controls. If you watch it, we explain how you can wire your own custom controls (including modifying an Easy Button!).
We also have show notes (pdf) for the episode, with schematics of how to wire up your own controls using switches and potentiometers.
Check it out, I am pretty sure it will show you exactly what you want.
Adding to pneumatic piston oaktown1188 Pneumatics 2 14-02-2006 12:11
Adding Code haywirerobotics Programming 2 18-01-2006 07:04
Adding objects Matthew_H 3D Animation and Competition 5 12-02-2004 19:33
Adding RAM to RC archiver 2001 1 24-06-2002 00:59
Adding my Thanks archiver 2000 0 23-06-2002 22:57
