Re: Car Nack Predicts 01/08/07
Why? It's much harder to score them there than at the top.
How so?
With the lower racks you can pre-align the robot up positioned with the keeper to run into a bottom rack scorring spider leg and you will be golden. The only thing you have to worry about is the "slight adjustment" after you set up your robot, but I don't think that will make much of a difference. What is your reasoning Cory? I'm guessing less leg shake up above, and the target to help you? Maybe, but it also constitutes actuating an arm or something to reach that high as well. I know from past experience it takes quite a while to drop a tetra on a goal in autonomous mode. The only advantage this year is you start with the game piece in your possession. |
I strongly disagree with Billfred. I predict that in _very_ few matches will less than one keeper per team be scored. The spiders are nigh impossible to shake without a running start, and barring collisions any team with halfway competent programmers (a group among which I count myself) should be able to score underneath a light.
In short, IMHO Car Nack is dead wrong. But I've been wrong many times before. |
In terms of coding difficulty, if the team is using closed loop control (or has done enough testing to know how long to run the motors to get their manipulator to the right height), it should be no more difficult to score on the higher spiders during autonomous (in fact easier due to the lesser shaking) than down low. As for Car-Nack. It really depends on how good 383 and the rest of the Brazilian teams are this year, because that's the only regional I could see less than 5 keepers scored. Not knocking the Brazilians in any way, it's just a much smaller and younger event (even than Israel). |
| Car Nack Predicts 6/06 | Car Nack | Car Nack's Corner | 13 | 21-04-2008 03:11 |
| Car Nack Predicts 1/06 | Car Nack | Car Nack's Corner | 13 | 05-04-2006 08:02 |
| Car Nack Predicts 05/06 | Car Nack | Car Nack's Corner | 6 | 03-03-2006 07:45 |
| Car Nack Predicts 3/06 | Car Nack | Car Nack's Corner | 39 | 28-02-2006 22:19 |
| Car Nack Predicts | archiver | 2000 | 2 | 23-06-2002 21:59 |
