Go to Post Nobody has ever complained that someone was too willing to share their knowledge of building robots or their new ideas for anything. - Josh Hambright [more]
Unread 08-01-2007, 13:32
mprikril mprikril is offline
FRC #0056 (R.O.B.B.E.)
mprikril is a jewel in the roughmprikril is a jewel in the roughmprikril is a jewel in the rough
Exclamation _entry_scn error on building
I am attempting to build Kevin's code with the streamlined camera program and I get an error:
'_entry_scn' type is non-overlay and absolure but occurs in more than one input file.
This has come up before as noted in this closed thread: http://www.chiefdelphi.com/forums/sh...ght=_entry_scn but I'm not entirely sure if I know what to do to fix it - as it seems like it shouldn't happen
Has anyone else run into this?
Thanks
Unread 08-01-2007, 14:05
Re: _entry_scn error on building
Are you compiling Kevin's original code without any changes of your own?
If you've changed any files in the project which ones are they and what did you change?
Unread 08-01-2007, 14:50
It was entirely Kevin's code. I had not changed a thing.
In the thread that was closed that I mentioned above, the user just tried again with a fresh download of Kevin's code. I downloaded his code again and tried, and it built with no errors. So we're back in business - or rather, we're at step 2 of 1000 - but you get the idea
That fact that it works now is odd, but not entirely unexpected.
Unread 08-01-2007, 16:11
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Did you try to do a "Rebuild-all"? That is the button next to the build button.
Worked for me
Try that
Cheers!
Unread 08-01-2007, 16:15
That sort of error seems to be common when you change project directories and don't do a "clean" make. It looks like MPLAB keeps some information around about the previous project and tries to link both the old and new object files.
I believe it always goes away if you "build all" instead of just doing a normal fast compile of only the changed files, or if you delete all the intermediate files before compiling.
Unread 09-01-2007, 21:21
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
are u sure u arent calling any files like this??
#include camera.c
because that can cause a major problem...
do it like this instead
#include camera.h
also i had this problem once... sometimes if u uninstall MPLAB and reinstall it... it sometimes works that waay...
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 16-01-2007, 22:06
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
This is my problem too, but whatever has been suggested above and in many other places doesn't cure my woes. I've even taken the code from a "good" code" subdirectory to a 2nd computer and matched up all the options side by side. Everything matches (except see below for $(INCDIR)).
As Alan Anderson says, I copied a subdirectory of good code to another directory. After all, you want to be able to fall back to good code if you mess up the newer code. If this can't be done MPLAB is a bit useless. I've always done "Build All", and as Alan suggests, I've tried the "Clean".
The only difference is the Include Path $(INCDIR) -- the good code had none in "Build Options" General. With none in the "bad" code, I get
C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera.c:30:Error [1027] unable to locate 'stdio.h'
Adding a path C:\mcc18\h to $(INCDIR) gets me thru all the Executing's and stops at MPLINK with
Error - section '_entry_scn' type is non-overlay and absolute but occurs in more than one input file.
I suspect this is the problem, somehow duplicating includes, but how else does one locate stdio.h?
From the microchip.com forum (via Google), I've found this (lets see if I can do quotes):
It's the Linker complaining that: _entry_scn occurs in more than one input file.
_entry_scn is a label in the startup files (c018x.o)
This should only be added in the linker script at the "FILES".
You probaly have this included in somewhere else your project *.mcw which you shouldn't.
I'm not quite sure what the bolded part means (bolding mine). I'd ask there but that thread is a year old. I've only got the usual files in the .mcw -- the *.c and *.h, plus FRC_library_8722.lib and 18f8722.lkr. There are no #include *.c's -- it's the same code between the two subdirectories!
Any suggestions?
Roger.
PS-- At least I'm not getting an error regarding "Generate_Pwms(pwm13,pwm14,pwm15,pwm16);"!
Unread 17-01-2007, 12:48
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Build all and look at the last line before MPLINK in the output window, is it similar/identical to the following:
Executing: "E:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\CPrj\2007\Default\18f8722.lkr" "C:\CPrj\2007\Default\main.o" "C:\CPrj\2007\Default\user_routines_fast.o" "C:\CPrj\2007\Default\user_SerialDrv.o" "C:\CPrj\2007\Default\ifi_startup.o" "C:\CPrj\2007\Default\ifi_utilities.o" "C:\CPrj\2007\Default\user_routines.o" "C:\CPrj\2007\Default\FRC_library_8722.lib" /m"FrcCode.map" /o"FrcCode.cof"
In your .mcw project window, find and double click the 18f8722.lkr file to open it. This is the linker file. In it should be the following near the top:
//FILES c018i.o
FILES clib.lib
FILES p18f8722.lib
This is what the "FILES" comment refers to. The libraries are pulled from $(LIBDIR), which you can find when you open Project -> Build Options -> Project and select "General" tab. Under the same view, verify that the "Linker-Script Path" which is located at the bottom of the window is blank (see attached figure) - otherwise the project could pull in the default linker file... which as we will get to shortly can cause this error.
NOTE: The ifi provided linker file is different from the default linker file that comes from Microchip - the ifi version has the c018i.o reference commented out. If the line is missing the '//', add them in and rebuild all. If the linker file is ok, take a close look at the "Executing... mplink..." line in the build output window. Is the project picking up the linker file from the project directory or from the Microchip default directory? Referencing the wrong one will cause the problem.
I changed my linker file by uncommenting the "FILES c018i.o" line as follows to force the error in my project:
FILES c018i.o
FILES clib.lib
FILES p18f8722.lib
The error message appears, as expected in this case:
Copyright (c) 2004 Microchip Technology Inc.
Errors : 1
That's because the linker file is now the same as Microchip's which includes the entry section in c018i.o (you can see this in \mcc18\lkr directory).
So the error message is indicating that somewhere in the link procedure it is encountering multiple modules that are defining the _entry_scn, but it only wants one definition. See section 2.9.1.4 of the C18 user guide under reserved section names for a description of this reserved section. Hopefully you haven't attempted to create another section of this name. If you don't think so, then you didn't. You'd have to add pragma statements defining the section name.
I used mplib /t on the libraries, but they look clean. I then looked into the View -> Disassembly Listing of the project and found that this section is declared in ifi_startup.c:
27: #pragma code _entry_scn=RESET_VECTOR
28: void _entry (void)
29: {
30: _asm goto _startup _endasm
00800 EF9E GOTO 0x393c
00802 F01C NOP
31:
32: }
00804 0012 RETURN 0
Neither map or listing file will be generated if there are linker errors. So, if you want to trouble shoot this more you can change the ifi_startup.c temporarily by adding "#ifdef NEVER" just before the pragma statement in ifi_startup.c and adding an "#endif" at the end of that file.
#ifdef NEVER
void _entry (void)
#endif
Rebuild all.
Now, View -> Disassembly Listing (this assumes it now builds without errors). In this file do a View->Find for _entry_scn - scroll up and you will find which file is definining this section. Now at least you know which file is causing the problem and you can figure out how the linker is getting this file.
In my example:
--- C:\mcc18\src\traditional\startup\c018i.c ---------------------------------------------------
1: /* $Id: c018i.c,v 1.3 2004/07/30 17:28:43 ConnerJ Exp $ */
2:
3: /* Copyright (c)1999 Microchip Technology */
4:
5: /* MPLAB-C18 startup code, including initialized data */
6:
7: /* external reference to the user's main routine */
8: extern void main (void);
9: /* prototype for the startup function */
10: void _entry (void);
11: void _startup (void);
12: /* prototype for the initialized data setup */
13: void _do_cinit (void);
14:
15: extern volatile near unsigned long short TBLPTR;
16: extern near unsigned FSR0;
17: extern near char FPFLAGS;
18: #define RND 6
19:
20: #pragma code _entry_scn=0x000000
21: void
If this doesn't help or there are still problems, then cut and paste the "Executing ... mplink... " line from the mplab output window so we can see what is being linked together.
AND DON'T FORGET to remove the #ifdef NEVER...#endif from the ifi_startup.c file when done troubleshooting!
Bud
Unread 18-01-2007, 07:37
FRC #1153
Rookie Year: 1900
Wow! dcbrown thanks for your answer. The "//FILES c018i.o" was the final link to success. I've gotten good builds on the "bad" code, a subdirectory copy of a good code, and even on a separate computer. I never even thought to look in 18f872.lkr, let alone think it was a text-readable file. Next step is PROGRAMMING!
I have only one possible nit to pick, in case others are following along.
Verify that the "Linker-Script Path" just below the $(LIBDIR) is blank...
Should that be $(LKRDIR)? The picture you have is what I did.
Again, many thanks!
Roger.
Unread 18-01-2007, 12:26
AKA: Bud
Poor choice of english on my part. I'll go back and edit it.
What I MEANT to say (really!) was to reference the whole linker-script dialog section which is below the libdir dialog which I referenced earlier. It is confusing the way it is currently written - I'll change it.
Bud
Unread 18-01-2007, 15:23
FRC #1153
Rookie Year: 1900
I knew what you meant to say (I think), but it was mostly in case anyone else had the problem. Besides, I was following the pictures!
Unread 18-01-2007, 18:41
FRC #1153
Rookie Year: 1900
Okay, dcbrown (insert #$^#&(*$% smilie here) unfortunately I didn't have access to the robot when I built the code. In the IFIloader, when I open the .HEX code, it pops open with a small window with the message
Invalid Address : 0x20 (Correct Range : 0x800-0x7fff)
[OK]
Which, I am guessing, some part of the compiler is giving the wrong starting address. Now what?
Unread 18-01-2007, 20:07
AKA: Bud
In build output window, what does COFF to HEX file converison look like?
MP2HEX 3.90, COFF to HEX File Converter
Errors : 0
In MpLab, File -> Open, select FrcCode.hex. Once open, it should look something like:
:020000040000FA
:060800008AEF1CF012005B
:020806001200DE
:06080800ECEF0DF0120000
:02080E00C250D6
But in yours the file has an error message? I haven't had any of these problems with the default code.... yet. Which IFI loader version are you using?
Unread 19-01-2007, 14:21
FRC #1153
Rookie Year: 1900
I’m sorry this is taking so long. I thought with the //FILES c018i.o I was free and clear!
Both the MPLAB and IFIloader are from last year’s kit. We’ve loaded this year's disk on other computers, but at the time we only had last years set and ready. Also, the robot code is last years, and we’ve been loading it onto last year’s robot.
Right now I’m not with the computer nor robot, but I have my own computer with duplicates of everything. It also tested the code and compiled successfully, just to see if a different computer can do it.
Here is the output from the last successful build:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera_menu.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\eeprom.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_startup.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_utilities.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\main.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\serial_ports.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\terminal.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking_menu.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines_fast.o".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera.c" -fo="camera.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera_menu.c" -fo="camera_menu.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "eeprom.c" -fo="eeprom.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "main.c" -fo="main.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "serial_ports.c" -fo="serial_ports.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "terminal.c" -fo="terminal.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking.c" -fo="tracking.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking_menu.c" -fo="tracking_menu.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\mcc18\lkr\18f8722.lkr" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera_menu.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\eeprom.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_startup.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_utilities.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\main.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\serial_ports.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\terminal.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking_menu.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines_fast.o" "C:\mcc18\lib\FRC_library_8722.lib" /m"2007-01-14 TEST.map" /o"2007-01-14 TEST.cof"
MPLINK 3.90, Linker Copyright (c) 2004 Microchip Technology Inc. Errors : 0 MP2COD 3.90, COFF to COD File Converter Copyright (c) 2004 Microchip Technology Inc. Errors : 0
MP2HEX 3.90, COFF to HEX File Converter Copyright (c) 2004 Microchip Technology Inc. Errors : 0 Loaded C:\CODE\0601-SHOOTER\2007-01-14 TEST\2007-01-14 TEST.cof. BUILD SUCCEEDED: Fri Jan 19 06:42:17 2007
Note the COFF to HEX part matches yours.
Here is 18f8722.lkr:
// $Id: 18f8722.lkr,v 1.2 2004/09/13 22:07:05 curtiss Exp $
// File: 18f8722.lkr
// Sample linker script for the PIC18F8722 processor
LIBPATH .
//FILES c018i.o
FILES clib.lib
FILES p18f8722.lib
CODEPAGE   NAME=vectors    START=0x0            END=0x29           PROTECTED
CODEPAGE   NAME=page       START=0x2A           END=0x1FFFF
CODEPAGE   NAME=idlocs     START=0x200000       END=0x200007       PROTECTED
CODEPAGE   NAME=config     START=0x300000       END=0x30000D       PROTECTED
CODEPAGE   NAME=devid      START=0x3FFFFE       END=0x3FFFFF       PROTECTED
CODEPAGE   NAME=eedata     START=0xF00000       END=0xF003FF       PROTECTED
ACCESSBANK NAME=accessram  START=0x0            END=0x5F
DATABANK   NAME=gpr0       START=0x60           END=0xFF
DATABANK   NAME=gpr1       START=0x100          END=0x1FF
DATABANK   NAME=gpr2       START=0x200          END=0x2FF
DATABANK   NAME=gpr3       START=0x300          END=0x3FF
DATABANK   NAME=gpr4       START=0x400          END=0x4FF
DATABANK   NAME=gpr5       START=0x500          END=0x5FF
DATABANK   NAME=gpr6       START=0x600          END=0x6FF
DATABANK   NAME=gpr7       START=0x700          END=0x7FF
DATABANK   NAME=gpr8       START=0x800          END=0x8FF
DATABANK   NAME=gpr9       START=0x900          END=0x9FF
DATABANK   NAME=gpr10      START=0xA00          END=0xAFF
DATABANK   NAME=gpr11      START=0xB00          END=0xBFF
DATABANK   NAME=gpr12      START=0xC00          END=0xCFF
DATABANK   NAME=gpr13      START=0xD00          END=0xDFF
DATABANK   NAME=gpr14      START=0xE00          END=0xEFF
DATABANK   NAME=gpr15      START=0xF00          END=0xF5F
ACCESSBANK NAME=accesssfr  START=0xF60          END=0xFFF          PROTECTED
SECTION    NAME=CONFIG     ROM=config
STACK SIZE=0x100 RAM=gpr14
Here is the .HEX code:
:020000040000FA
:06002A000B00156600004A
:100030004B0300000A000000136600006E0300007E
:10004000020000000E6600005503000005000000DD
:100050000A6600006603000004000000F16500006D
:10006000C702000019000000EF6500006C030000EB
:1000700002000000EB6500006203000004000000C5
:10008000E5650000F7020000060000000608000019
:100090006A03000002000000DE650000F9010000B4
:1000A000070000001265000000010000CC00000005
<snip>
:10659000000201320005020A0005010A0005020A94
:1065A000061600FE63FE0002012800FE63FE0002E4
:1065B000061600FE63FE00020A0A00FE63FE0002E9
:1065C000012800020A0300FE63FE0002011E000211
:0E65D0000A0300FE63FE070002000000000048
:0265DE000000BB
:0565E0007F7F000000B8
:0665E500000000000100AF
:0465EB0000000000AC
:0165EF00FEAD
:0165F000FFAB
:0F65F10000000100000000000001000000000198
:0A660000000000000000010000008F
:04660A00000000008C
:02660E0000008A
:0366100001000086
:02661300000085
:0A6615000000000000000001010178
:020000040030CA
:0E000000FF36F6FEFFFF8BFFFFBFFF9FFFBF27
:00000001FF
(I’ve snipped out the exciting middle 1000 lines.) I’m assuming the beginning numbers on each line are some hexadecimal address, except yours stays low, but mine jumps up to the 1000’s at the 3rd line.
Build Options – General:
Include Path: C:\mcc18\h
Library Path: C:\mcc18\lib
(all others blank)
Finally, I’ve attached a picture of the MCW list, and one of Build Options – MPLAB C18. -- Well, I would have, except it's not doing what I thought
Build Options, MPLAB c18 tab, Use Alternate Settings:
-mL -Ou- -Ot- Ob- -Op- -Or- -Od- -Ooa- -nw=2066 -D_FRC_BOARD
mcw ~ mcp list: Along with all the C and H files, FRC_library_8722.lib and 18f8722.lkr.
One final thing. I took Kevin.org's frc_camera_21.zip files and compiled them successfully, straight out of the box, butgot the same error with IFIloader. The HEX file supplied successfully downloaded.
Hopefully this is enough for you. If I have to I can get to the school tonight for more, but I’ll be there tomorrow for sure. The internet is a little flaky there, so it’s a choice of being next to the robot or on the internet. Thanks again for your help!
Roger.
Unread 19-01-2007, 15:03
AKA: Bud
Nothing obvious to me. I'll need to try a few things on our bots this weekend, but at this point I'm out of ideas.
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Building material archiver 2000 1 24-06-2002 00:10
Goal Building archiver 2001 0 23-06-2002 22:51
