Go to Post Elevator speeches too - everyone should have one. - Swan217 [more]
Unread 08-01-2007, 17:02
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: SPI Port on Robot Controller
All the io lines are noise filtered with RC networks. The io lines that support analog inputs being the most heavily filtered( about 5x the normal digital io lines), the interrupt io pins being the least filtered (about .1x). Be aware that:
MYSPI_CLK = 1;
mask >>= 1;
MYSPI_CLK = 0;
would probably work ok in a bare PIC18F environment, but with the digital lines spec'd to max 50Khz response time (20us?) the above clock pulse will never show up at the IFI controller pin. You'd likely need to add lots of nop delay to wait for the rise time on the pin and also filter it through a schottky or some other type of buffer to clean up the slow rise "pulse" into a real clock edge.
http://www.ifirobotics.com/rc.shtml#Specifications
http://www.ifirobotics.com/docs/anal...al--i-o-rc.pdf
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Robot Controller NotaNerd Control System 6 04-11-2004 16:53
Software SPI Interface Greg Programming 11 08-02-2004 21:38
MSC and SPI Parts Usage sanddrag Kit & Additional Hardware 1 05-01-2003 03:23
SPI Requirement To Purchase archiver 2001 3 24-06-2002 00:33
