Go to Post how can anyone Not Notice An entierly Pink Team? - Tytus Gerrish [more]
Unread 08-01-2007, 17:05
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: 2 Cmucams?
Originally Posted by Kingofl337 View Post
I think that many interrupts per second would kill the controller anyways. 11520 interrupts a second x 2.
Again, you don't have a clue what you're talking about. Please stop spreading disinformation around the forums.
The camera only generates a few hundred interrupts per second, one per byte received. The serial driver is very efficient and can easilly handle this load.
Furthermore, there is no reason that you couldn't have two instances of the camera code running, you just need to make sure each instance isn't using the other's global variables.
-Kevin
Kevin Watson
http://kevin.org
