Go to Post ... my most important lessons in life all came from one place, Sesame Street. - Karthik [more]
Unread 08-01-2007, 15:31
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Gear assembly instructins needed
im sorry if this has already been asked, mi didnt find any resluts so here's my question:
Where are the Gear assembly instructions?
We have connected the CIM motor to the Gear Box of bane bots, and we cant find how/with what should we connect the gear to a wheel...
we seem to be missing an adapter which locks the hinge to a sprocket and then a wheel.
Thanks for the help.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2007, 15:54
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Gear assembly instructins needed
The drive system is essentially the same as last year. The small sprocket goes on the output shaft of the CIM/Banebot transmission. You will need a key for the small sprocket. The large sprocket is attached to the wheel. Chain connects between the two.
Instructions from last year can be adapted for many different mechanisms. The best part about this competition is that is not a true kit. You have to design and modify instead of just assembling.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 08-01-2007, 17:02
mrhankeydapoo's Avatar
mrhankeydapoo mrhankeydapoo is offline
Pit Crew
AKA: Joe P.
FRC #2064 (The Panther Project)
mrhankeydapoo is an unknown quantity at this point
Send a message via AIM to mrhankeydapoo
where is the key used to connect the banebots transmision to the small sprocket?
is it included in the kit of parts or does it have to be purchased seperately?
does anyone know the size of the key needed?
Unread 08-01-2007, 17:07
Tottanka's Avatar
AKA: Liron Gurvitz
That's exactly what im looking for...
Unread 09-01-2007, 08:11
Engineer
If you measure the width of the keyway in the shaft, that is the key size. Since I do not have one with me, I am guessing that is 1/8" square (per KOP checklist = 1/8"). Easy to find in the USA from McMaster. The key material is a little oversize and may need filing to fit. I buy the steek square stock instead.
This is not in the kit as far as I can see.
Andy Brockway
Gear Help Needed- Urgent psychoCHIPMUNKK Technical Discussion 6 05-02-2004 13:44
2004 Drill motor and gear assembly number LamdaCubed Motors 4 27-01-2004 22:47
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
Help Needed On Gear Box geo Technical Discussion 10 02-10-2003 18:25
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
