Go to Post Have I ever poked fun at you? OK, maybe Heidi. and JVN. And Dave Lavery. and Andy Baker. and .... all right, I guess I deserve it. - Gary Dillard [more]
Unread 06-01-2007, 19:11
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
Torque vs. Current in small CIM motors
Hey,
We are trying to design our drive chain using the small CIM motors. We want to know how much torque we can get out of our motors without triping the breakers. Is there such thing as a torque vs. current graph? If so does anyone know where we can find it?
-Martin Cacan
Unread 06-01-2007, 19:31
AKA: Dr. Brooks
no team (WRRF)
Re: Torque vs. Current in small CIM motors
Originally Posted by robotguru1717 View Post
Hey,
-Martin Cacan
The FIRST Guidelines, Tips and Good Practices, from 2005,
lists this motor as 346.9 oz-in at a stall current of 114 amps.
The torque is proportional to the current, so multiply the
torque figure by 40/114 and you should have a number that
is good enough for your purposes.
There were anamolies in the 2005 table, so you should check
the stall torque and current in some of the other other tables
that appear in the sticky threads in the motors section.
Have fun,
Eugene
Unread 08-01-2007, 17:09
Aboynamedkim55's Avatar
Aboynamedkim55 Aboynamedkim55 is offline
AKA: Alex Kimmelman
FRC #0075 (The Roboraiders)
Team Role: Electrical
Aboynamedkim55 is a jewel in the roughAboynamedkim55 is a jewel in the roughAboynamedkim55 is a jewel in the rough
Send a message via AIM to Aboynamedkim55
Also it depends on what transmssions you use. if you use one motor trannies you get less torque. If you use the two motor trannies then you get more power but then you can't use any more CIM motors.
From personal experance you wont trip the breaker aslong as you run 40 amps to the motor. Remember to use PWM Y-cables if your using the duel motor trannies
Proud to be a J&J Team
-2007 Chesapeake Winners with 293 & 203
-2007 Chesapeake GM Industrial design
-2007 NJ regional Chairmans award
-2007 NJ regional Autodesk visualization award
-2006 NJ regional engineering inspiration award
-2006 Boston regional Autodesk visualization award
-2006 Boston regional engineering inspiration award
Small CIM Gear Specs Joe_Widen Technical Discussion 2 03-04-2006 23:10
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
Torque on motors... archiver 2001 2 23-06-2002 23:08
Sensible Torque/Speed/Current Graphs l1jmx Rules/Strategy 2 10-01-2002 09:47
