Go to Post Corndog is the new water game. - Basel A [more]
Unread 08-01-2007, 17:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Chassis Clearance
A low side may actually be preferable for lifting (assuming the lift can still fit beneath it). The higher the side, the higher the lift has to travel (and the greater amount of its maximum range) before it contact and begins to lift the actual robot.
For example. If a lift is designed to go 5" high, but the bottom of the robot's frame is 3" high, the bottom of the robot's wheels will only be 2" high when the lift is fully raised.
Unread 08-01-2007, 18:02
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
yeah yeah that is true we thought about that. Let hope we get some but not too much clearance lol
Minimum Clearance? Cyberguy34000 General Forum 9 10-01-2006 11:13
Chassis? jakey Kit & Additional Hardware 1 09-01-2006 15:10
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
Victor Muffin Fans - Height Clearance? Mr. Lim Electrical 4 28-01-2005 15:32
