Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
Unread 08-01-2007, 18:29
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Banebot Gearbox
Ah. Thank you.
Unread 08-01-2007, 19:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Banebot Gearbox
Originally Posted by Ben Piecuch View Post
I haven't pulled apart the gearbox yet, but I was wondering the same thing. Dr Joe, care to give an answer to this?
While picking up the KOP at the Manchester Kickoff, I noticed that FIRST had built a couple practice bots. One robot used the new Banebot Trannies, and left the drive shaft fully cantilevered. Below you can find a picture. I was quite surprised to see if used in this configuration.
I don't think I'll be using it in this configuration, but YMMV.
BEN
Whoa! I don't know how I missed seeing that picture earlier but to me, that is about the scariest picture I have seen in a long time.
Perhaps the bearings inside that gearbox are better than I thought, but I would have never never never hung a sprocket that far out on that shaft.
I am thinking that the only way they got away with it was that they weren't really using it in competition and they must not have had the grippiest of tires.
Looking at that picture sends shivers down my spine! Really -- read this post for more on my views of emotion and engineering.
Joe J.
Team #88, TJ2
Unread 09-01-2007, 20:21
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: Banebot Gearbox
Originally Posted by Gabe View Post
All of the Banebots screws are metric (I had fun taking it apart), and if you dont use metric then you will strip the socket heads.
Agreed,
They are definitely metric. Go get your self a good set of ball end metric allen wrenches.
- Bochek
Unread 09-01-2007, 20:53
ChrisR_522's Avatar
ChrisR_522 ChrisR_522 is offline
FRC #0522 (Robo Wizards)
ChrisR_522 is an unknown quantity at this point
Send a message via AIM to ChrisR_522 Send a message via MSN to ChrisR_522
Re: Banebot Gearbox
Originally Posted by Nick 568 View Post
Thanks, we've added more grease, but still nothing. I look forward to your response though!
UPDATE: We figured out what the problem was, apparently, the bushing was too long on one of the motors, so we ground it down on the lathe and all is well!
We were experiencing the same problem with the gearbox as well, the bushing was indeed too long. It was trimmed with the lathe and voila!
Unread 09-01-2007, 21:43
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
Re: Banebot Gearbox
Anywhere I could get specs on the gearbox? (load capacity, structural integrity, etc.) We're thinking of using these for our bot's chain-driven 4WD, but we aren't sure what they can handle.
Madness?
THIS IS F.I.R.S.T!
Unread 09-01-2007, 22:01
gzevenbergen gzevenbergen is offline
FRC #1826
gzevenbergen is an unknown quantity at this point
Re: Banebot Gearbox
The allen screws in the end plate are 2mm metric. (the label reads made in China)
Unread 10-01-2007, 01:26
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Re: Banebot Gearbox
We need them too!!
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 10-01-2007, 01:31
CraigHickman
Posts: n/a
Re: Banebot Gearbox
I'm noticing a great number of posts on the lack of QC on the BB transmission... Should my team be worried about maybe using this, as lack of QC can mean robot failure at the most inapprapriate time?
Unread 10-01-2007, 01:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Banebot Gearbox
What exactly does the bushing being too long do to cause it to bind? Does the pinion on the CIM hit the planet carrier?
Unread 10-01-2007, 01:58
afphillips's Avatar
afphillips afphillips is offline
FRC #1515 (MorTorq)
afphillips will become famous soon enoughafphillips will become famous soon enough
Re: Banebot Gearbox
anyone know how reliable the new BB 2 CIM gearbox adapters are?
Unread 10-01-2007, 02:05
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Banebot Gearbox
If anyone from FIRST is reading this, please include 1/2" shaft collars next year because it was no fun having to retain the sprockets onto the shaft with duct tape.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 10-01-2007, 03:00
Re: Banebot Gearbox
I suppose a trip to a hardware store or web browser was out of the question?
Unread 10-01-2007, 03:33
Gabe's Avatar
Re: Banebot Gearbox
No, what I mean that since the Kit of Parts should include the materials for any team to build a basic robot, they could have included some shaft collars in the crates.
Unread 10-01-2007, 10:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Banebot Gearbox
It should? Says who? (remembering the days when all we got in the Kit Of Parts was a surplus computer printer and a Small Parts Incorporated catalog...)
-dave
Unread 10-01-2007, 10:56
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Re: Banebot Gearbox
Originally Posted by Gdeaver View Post
I too have concerns about shaft loading on the BB trans. If we were to use the 2 cim adapter and use 2 sprockets to duplicate last years 4 motor 4 wheel drive kit bot, can the 56mm trans take that shaft load and input? Has it been tested. Is the bearing support necessary for a 2 sprocket load? Can the 56 mm trans handle 2 cims? Would a safer bet be 4 cims 4 trans? Joe any comments?
I actually emailed BaneBots tech support for EXACTLY this question. Here is their response:
The two motor adapter does not change the gear reduction so in a best case [assuming no mechanical loss] the RPM would be the same as with 1 CIM motor and the torque would be twice that of a single CIM motor.
The 56mm gearbox and two motor adapter was specifically designed for FIRST applications and we believe they will support two CIM motors.
BaneBots
I don't know though---It doesn't seem like that little sucker can handle those two big CIMs. I'd hate to find out the wrong way.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Kit GearBox Talha Kit & Additional Hardware 2 10-01-2006 21:30
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
Gearbox ZACH P. Motors 4 09-02-2003 20:14
GearBox Working Balbinot General Forum 2 08-01-2003 22:12
