Go to Post Calling the refs "zebras" is just fine. Just don't call 'em late for dinner (or visually impaired). - EricH [more]
Unread 08-01-2007, 18:09
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Funny Video: Use of pump
http://www.frc-1947.com/Stuff/vacum1.avi
http://www.frc-1947.com/Stuff/vacum2.avi
The pump might be ver sefull as you can ssee here =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2007, 20:28
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Re: Funny Video: Use of pump
What is powering the vacuum?
Unread 08-01-2007, 20:46
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
wow.. I didnt think that it was going to even be moderatly effective.. Good you guys showed me different!
Unread 08-01-2007, 20:55
Tottanka's Avatar
AKA: Liron Gurvitz
The pump kit includes the pump, a cable and a specail part which chanes air pressure into vaccume.
You connect between the pump and a cyilnder whichi is connected to the Air compressor.
here'a a pic of that
Takes it bout 2 seconds to have enough ressure to lift rings...
Only problem is that it is much heavier then a motor so we wont use it...
WE ahve alread decided that we are gonna be able to pick 2 bots up with a little ramp of about one degree... one ramp at each side of the bot
and plus an arm which will make us be calss 1 or to, havent decided yet...
Unread 08-01-2007, 22:02
Larkinator's Avatar
Larkinator Larkinator is offline
FRC #0125 (The Nu-Trons)
Team Role: Driver
Larkinator is a jewel in the roughLarkinator is a jewel in the roughLarkinator is a jewel in the rough
That was one of the first things that we did when we broke our kit open. I was suprised by how much power the tiny thing had!
Unread 08-01-2007, 23:07
mizscience's Avatar
mizscience mizscience is offline
your friendly geek-next-door
AKA: Melissa Smith
FRC #1251 (TechTigers)
mizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of light
wow, that is really strong. we were throwing that idea around initially, but had written it off. I'm sure we'll consider it again once we've experimented more with it.
Once a TechTiger, always a TechTiger.
@mabsmith
Currently a PhD student in VA, volunteering at the DC/FL Regionals and Championships.
16 years and counting with FIRST! FIRST changed my life; how's it changing yours?[/size]
Unread 09-01-2007, 00:34
IA-Howitzer's Avatar
IA-Howitzer IA-Howitzer is offline
Theiss
AKA: Andrew Theiss
FRC #0100 (Woodside High Robotics)
IA-Howitzer is on a distinguished road
Send a message via AIM to IA-Howitzer
We came up with realtively the same results, but the issue was mainly when we tried to turn the object we were picking up. The turn causes the cup to break suction a lot easier when it is hit, so we are probably not going to go with the cup...
2005 - Mechanics Co-leader
2006 - Team Leader
2006 - Davis "Delphi Driving Tomorrow's Technology" Award
2006- Silicon Valley Regional "Display" Award
2004 - Silicon Valley Regional 2nd Place
Unread 09-01-2007, 00:44
Tottanka's Avatar
AKA: Liron Gurvitz
A neat solution is simply having 2 pumps attached to each other.
It will give you 2 points of possesion with the ring instead of one, and then u can wasily roatet it... and, it wont take more power from the compressor as it already has 2 exits =]
Unread 09-01-2007, 01:29
COACHTJ1688's Avatar
COACHTJ1688 COACHTJ1688 is offline
-STICKSHIFT ROBOTICS-
AKA: TJ
FRC #1688 (Stickshift)
COACHTJ1688 is an unknown quantity at this point
2 suction cups sounds like an awesome idea. perhaps a rotating end effector.
"If you can't fix it with duct tape...you haven't used enough duct tape."
Unread 09-01-2007, 23:57
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Yah, I was wondering if more than one vacume converter and or cup was allowed... but I haven't looked yet either.
And I gather that the vacume converter requires an airtank upstream? I wonder why!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 10-01-2007, 01:01
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
I don't think this set up would be allowed in competition since it wouldn't be at 60psi. We set up the vacuum and it is powerful but it pretty much requires the compressor to be running constantly. It doesn't always pick rings up on the seams. Also keep in mind that while it is very strong, the suction is broken if you touch the area near it. This might be a problem if a defending robots hits the tube or if you miss align and hit part of the spider legs.
Unread 10-01-2007, 03:11
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
Thumbs up Re: Funny Video: Use of pump
hahah wow it is strong were still on our mock up phase and havent tinkered with any parts yet but haha vid 2 was funny
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Unread 10-01-2007, 22:49
Adama's Avatar
Are all the parts needed to rig this up in the KOP?
Unread 10-01-2007, 23:02
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Yes. You have a venturi pump, a suction cup, 4 mm tubing, a compressor, 2 clippard tanks, all the pneumatic gauges and regulators and switches, and the fittings for the 4 mm tubes and the suction cup.
Unread 11-01-2007, 02:44
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
2 points of contact should significantly help with rotating.
The optimal pressure according to the piab site is 26 psig. This is well under the 60 psig max. The limit of 4 clippard tanks (at 120 psig) should be able to sufficiently power the vacuum device. Higher pressures are actually detrimental to the suction and it relies mostly on the air speed through the venturi type nozzle.
If a constant running compressor (vacuum generators can be air intensive) are a concern, vacuums can be constucted with KOP motors (which in a vacuum actually draw less amps).
Team 1511 video "learning how to use a alenwrench" Mirza95vx Robot Showcase 2 05-02-2005 17:36
Video Editing Programs...share what you use and why... Alexander McGee 3D Animation and Competition 25 09-01-2003 22:27
Pump RobDeCotiis Pneumatics 12 01-11-2002 21:31
Insulin Pump Melissa Nute Chit-Chat 2 17-10-2002 18:19
Pump Problems... archiver 2001 2 23-06-2002 23:58
