Go to Post Do you think Pizton's Lard would want to be a FIRST supplier and give every team some lard in the KoP? We could grease our gearboxes with it and every finals match could smell like bacon. - Ty Tremblay [more]
Unread 08-01-2007, 20:39
brennerator brennerator is offline
brennerator is an unknown quantity at this point
How to update hex?
How do I update the hex file...I changed the user routines.c ,but when does my hex update?
Unread 08-01-2007, 20:41
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: How to update hex?
I assume your using MPlab and not EasyC. You have to go to Project-->Build All
Unread 08-01-2007, 20:57
Oh ok Is there a way to do this in FusionEdit?
When i try to build in FusionEdit i get:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at FusionEdit.ServerProject.Build()
at FusionEdit.FusionServerForm.buildProjectToolStripM enuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
FusionEdit
Assembly Version: 0.1.0.0
Win32 Version: 0.1.0.0
CodeBase: file:///C:/Program%20Files/FusionEdit/FusionEdit.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Also can you describe the Limit_Mix function to me?
Unread 08-01-2007, 21:11
Team 2021 Captain
AKA: Chris Davidson
Fusion Edit isnt really a finallized product. You might be better off using MPlab or emailing/PMing the developers.
Unread 08-01-2007, 22:22
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Do you have the MCC18 compiler installed? I'm not too familiar with FusionEdit, but it looks to me like it is trying to invoke the compiler and cannot find it.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 08-01-2007, 22:25
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - mutliple inclusion of library file 'clib.lib'
Errors : 1
Im getting that error?
Any ideas?
Unread 08-01-2007, 23:08
Also when I use MP Lab I need a .asm file! what do I do?
Unread 09-01-2007, 09:49
In MPLab look under
Project -> Select Language Toolsuite
Make sure "Microchip C18 toolsuite" is selected.
Unread 09-01-2007, 10:34
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
When you are using fusionEdit you need to set the location of the compiler/linker/Loader ect.
Edit>Project Properties
defaluts:
Complier Path:C:\mcc18\bin\mcc18.exe
Complier Args:-p=18F8722 "SourceFile" -fo="ObjectFile" /i"C:\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Linker Path: C:\mcc18\bin\mplink.exe
Linker Args:/l"C:\mcc18\lib" LinkerScripts ObjectFiles LibraryFiles /o"OutputFile"
Loader Path: C:\Program Files\Intelitek\EasyC for FRC\Loader\iLoader.exe
Loader Args:/D=HexFile /T /B=1 /C=18F8722 /V /H
Eric Haskins KC9JVH
Hex vs. Key alysume Technical Discussion 12 31-05-2006 22:37
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
