Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Unread 08-01-2007, 19:24
Joel J's Avatar
Joel J Joel J is offline
do you..
Mounting encoders to the AndyMark
How have teams in the past mounted the grayhill 61k64 encoder (or any general shaft encoder) to the AndyMark shifters?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 08-01-2007, 19:27
Billfred's Avatar
Billfred Billfred is online now
Re: Mounting encoders to the AndyMark
I'm a few states away, but I recall 1902 just sticking a small wheel on their encoder shaft and mounting it such that it's in contact with a wheel. Would seem to work well, unless your wheels explode like theirs did in the Archimedes finals.
Unread 08-01-2007, 19:29
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Pardon me if I hijack your thread, Joel, but I thought this would be a good place to ask: is there a convenient spot in the Andymarks for mounting the gear tooth sensors, or do we have to make our own?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2007, 19:37
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Last year we put the gearbox in a mill and drilled a hole in the end of one of the shafts (output shaft i believe) and it worked well. This year we will probably have a live axle so we are attatching it to that.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 08-01-2007, 20:43
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I'd suggest drilling a hole in the sideplate and mounting a gear to the end of the encoders to mesh with the gears inside.
Unread 08-01-2007, 21:18
Billfred's Avatar
I found 341's solution from 2005 in my picture collection (hooray Capital Clash!). I'll put it up in CD-Media.
Unread 31-01-2007, 11:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
here is the link for those who may be looking for it (hoping to save someone the past 5 minutes I spent)
http://www.chiefdelphi.com/forums/sh...ad.php?t=51306
Unread 31-01-2007, 11:55
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Take a look at:
http://www.phxhs.k12.az.us/education...67&pagecat=300
Unread 31-01-2007, 12:00
MrForbes's Avatar
AKA: Jim
Thanks, I should have thought to look at our mentor team's web page
Looks like we need to get drivetrain and programming to discuss how much encoder resolution they want, and what interrupt rate they can live with, and what gear or roller ratio or direct drive from what shaft on the transmission will achieve that.
Unread 31-01-2007, 14:20
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
Originally Posted by N7UJJ View Post
Do you know where we could get the gear to attach to the encoder (preferably, a McMaster part number)? If not, do you know the specs on the gear so we could find something similar?
Unread 31-01-2007, 16:39
Jared Russell's Avatar
Taking a year (mostly) off
I will double check with our lead mentor what gear we used for this:
But I'm pretty sure it's just the CIM spur gear from the AM gearbox (you can get extras on the AndyMark site)
Unread 31-01-2007, 21:32
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We drilled a 1/2" diameter hole into one of the AM side plates, 1.125" away from the output shaft, center-center. Then squeezed in a 36 tooth, 32 pitch, nylon gear, bored out to 1/2" and keyed, on the output shaft where the sprockets are (we acually only used one sprocket). Then another of the same gear on the encoder and you're rolling!!! If you can't broach a keyway, just file one in the nylon gear. Nylon gears are at McMaster... part no... 57655K43 . They come with a 1/4" bore which fits the encoders, but you must bore this out for the output shaft. Here's some pics of our from last year...
ID:	4978  Click image for larger version
Mounting encoders? waialua359 Technical Discussion 4 13-02-2006 01:57
Mounting encoders? waialua359 Electrical 2 10-02-2006 22:21
mounting andymark wheels VEN Technical Discussion 10 04-02-2006 00:14
How do you mount the encoders to the Gear boxes? waialua359 Technical Discussion 5 01-02-2006 21:07
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
