Go to Post ASPCA would be happy to know you are petting your watchdog rather than kicking it. - Ether [more]
Unread 08-01-2007, 21:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Backup battery connector
Does anybody know the part number for the female cable connector that is attached to the backup battery, and/or for the corresponding male PCB-mount connector found on the old RC and EDU controller? There are some old threads about this, but nothing seems to have these exact parts.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-01-2007, 00:12
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Backup battery connector
These are Tyco/AMP MATE-N-LOK's. I don't have exact part numbers, but I have ordered them from digikey before.
Digikey also sells "RC-Car Style" connectors, which are great for making little adapter cables with these to use vex style batteries and other standard rc car batteries.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 16-04-2007, 16:03
dtengineering's Avatar
AKA: Jason Brett
While the IFI "backup batteries" may well be a MATE-N-LOK I believe digikey lists the connectors that connect to the VEX batteries as "Toy Car" connectors, with part numbers WM2308-ND (plug), WM2311-ND (socket), WM2309-ND (receptacle) and WM2310-ND (pin).
Note: The following does not follow official rules for VEX competitions. That doesn't mean it is unsafe or improper (so long as you have a "clue")... just don't plan on doing it at competitions. For classroom, demonstration, and other uses, however, once you have the correct connectors you have many alternative power sources for VEX robots.
For instance this means that you can purchase connectors that will allow you to adapt fast charging "peak detection" chargers to your vex batteries (you can reasonably charge most NiCd batteries at 3C, or six amps for the 2000MAh vex batteries, for a 20-minute charge rather than the two hour charge from the one amp VEX chargers.. and get a better charge as you are relying on peak detection, rather than temperature detection on when to stop charging) or adapt other battery technologies to your VEX robot. For those of us who fly RC electric airplanes, we have old Ni-Cd and Ni-Mh battery packs and peak chargers sitting around that are just perfect for use in VEX. But I won't be converting my Li-Polys just yet.
Jason
backup battery nirty Electrical 1 08-02-2006 14:40
Dump Backup Battery Kingofl337 Electrical 17 24-12-2005 13:44
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
