Go to Post Remember everyone, during build season, if you mess something up..... In the words of Adam Savage... Failure is always an option! (and so is blowing stuff up) - J.Warsoff [more]
Unread 08-01-2007, 21:33
brennerator brennerator is offline
brennerator is an unknown quantity at this point
What is the Limit_Mix function
Can someone describe this function to me?
Im trying to reduce the speed of the motors; how would I edit this:
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
Unread 08-01-2007, 21:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: What is the Limit_Mix function
The limit mix function is a bit of software that takes the two axes from one joystick, and calculates the corresponding PWM outputs. In order to adjust a PWM value by a constant factor, try something like this:
pwm01 = (pwm01-127)*0.75+127
There may be a typecasting issue there, so you'll need to play around with it. However, the idea is that you need to recenter the value around 0 (by subtracting 127), lessen the magnitude (by multiplying by less than 1), and then shift back to the normal range (by adding the 127 back). In this case, this code would reduce a motor to 75% of its original speed. If that doesn't make sense, feel free to ask for more clarification.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2007, 21:44
Thats perfect; THank you so much!
Also one problem; when I try to edit the MPLab code and build it it says no source files in teh project.
How do I get around this?
Unread 08-01-2007, 22:10
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
I believe that means you set up MPLab wrong when you were installing it. However, I'm not sure exactly what the problem is. Did you install the compiler first and then MPLab or the other way around?
xXx.S3nS31-h4nz0.xXx
Unread 08-01-2007, 22:14
the other way around. I set up MP lab then the compiler
Visual Basic. Using a loop to solve the cosine function. sanddrag Programming 2 10-03-2006 11:45
Arcade Function gabrielse Programming 1 08-02-2006 00:49
Limit_Mix() Function EricWilliams Programming 2 27-07-2005 23:19
Autocalibrate function Validius Programming 2 29-03-2005 21:59
FreeLibrary() Function Raven_Writer Programming 0 09-08-2003 15:39
