Go to Post me: "Was I on fire!?" Roberto: "Sure you were. We only let you burn for about 10 seconds.":yikes: - El Geffe [more]
Unread 06-01-2007, 23:54
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Vacuums!
"For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a pneumatic device and is allowed. This includes, but is not limited to, Venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by one of the Kit-of-Parts motors)."
I was curious, is this as easy as reversing the pump to suck?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 07-01-2007, 00:18
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Re: Vacuums!
I was curious, is this as easy as reversing the pump to suck? [/quote]
In my experience in custom airbrushing, due to the way the pumps move the air they dont create a substantial vacum on thier own. Idk about the first pumps but I know if i try using mine to suck it heats up fast.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 07-01-2007, 01:17
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: Vacuums!
In my experience in custom airbrushing, due to the way the pumps move the air they dont create a substantial vacum on thier own. Idk about the first pumps but I know if i try using mine to suck it heats up fast.[/quote]
I would NOT recommend hooking your pumps in reverse, due to the fact they were never built to work that way. (otherwise there would not need to be a resona to color-code the wires )
Eat, Sleep, Build Robots
Unread 07-01-2007, 02:13
Thorcat Thorcat is offline
FRC #1540
Thorcat is an unknown quantity at this point
Re: Vacuums!
If you look at the manufacturer's website, they say the the head is set up for compression only. Product Page
I would take this to mean that if you hooked something up to the suction side it would not create very much suction because the rubber piston seal would be useless.
Unread 07-01-2007, 02:14
Dranyam Dranyam is offline
Dranyam has a spectacular aura aboutDranyam has a spectacular aura about
Re: Vacuums!
Good idea! I wish i'd thought of it
Unread 08-01-2007, 21:51
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Vacuums!
The KOP compressor will not work as a vacuum pump, but it is not necessary when you have the KOP vacuum generator and suction cup. We tried picking up an inner tube with it, and it is more than enough to hold on to the tube.
Unread 08-01-2007, 21:58
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Vacuums!
the punp creates a lot of vaccum pretty fast as seen here:
http://www.frc-1947.com/Stuff/vacum1.avi
http://www.frc-1947.com/Stuff/vacum2.avi
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2007, 22:11
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Re: Vacuums!
Something we came up with, as an alternative (if we don't need the compressor onboard or just want to do something different) involved a piston, screw drive assembly, and a little motor.
The idea is that you rig up the end of the piston's rod to the nut of an acme thread (or KoP, whichever) screw drive and mount a small, fast motor to the screw. The piston is staged with the rod all the way in, with the nut at the extreme nearest point to the piston. Your vacuum line is connected to the piston at the opposite end from where the rod enters. The other end (nearest the rod) is left open to allow displaced air to escape.
When you want to produce a vacuum, all you need do is power that motor until it has driven/pulled the rod far enough to create the desired vacuum strength. You could reverse this idea and start with the piston all the way open and the vacuum line connected at the other fitting, then push the rod in until you have the desired strength. You also could push/pull the rod with a cable or lever or something else.
I think this is allowed, but I must admit that I haven't gotten too far in this year's manual yet.
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 09-01-2007, 14:13
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Vacuums!
[quote=Arkorobotics;549662]"(as long as they are powered by one of the Kit-of-Parts motors)."
QUOTE]
This is were the "got you" is. The air compressor is not a KOP motor. So, using it a vacuum device would not be allowed.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 09-01-2007, 14:28
Brandon Holley's Avatar
Re: Vacuums!
the compressor has a motor in it, and its in the kit of parts....
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 09-01-2007, 16:10
Greg Wood Greg Wood is offline
FRC #2042
Greg Wood is an unknown quantity at this point
Re: Vacuums!
Hey does anyone know where we can buy extra suction cups? And the hardware for that.
Unread 09-01-2007, 16:21
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Vacuums!
We made a vacuum generator in 2004 using a globe with a crank on the end of it to drive a pnuematic piston with check valves on it. It worked well. This is the type of mechanism that the rule refers to not reversing or some other way tampering with the compressor.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 09-01-2007, 16:24
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
Re: Vacuums!
Could you post a picture of you piston and valve idea or a larger description?
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 09-01-2007, 16:46
Re: Vacuums!
I don't have any pictures I can post. I'll see if I can get one at one of our meetings this week. As for a description, short of a P&I diagram of how to make the system work a picture is the only way to explain it so most people can understand what we did.
Thank-you 294 & 67
Unread 10-01-2007, 07:51
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Re: Vacuums!
That is true. But, the Compressor comes under the rules R99 to R106. You will have to present a good case to convince me that the cmpressor can be use as vacuum device
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
