Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 08-01-2007, 19:26
Kaushal.K's Avatar
Kaushal.K Kaushal.K is offline
Scouting & Things
AKA: kkaboose
FRC #1241 (THEORY 6)
Kaushal.K is an unknown quantity at this point
Question Motor with a built in Potentiometer..?
Are we allowed to use a motor with a built in potentiometer in order to control the arm/gripper thingy..? and by use it I mean.. is it allowed..? and would it make sense to use it..?
for more information on a Potentiometer please check :
http://www.chiefdelphi.com/forums/sh...otentio meter
FRC Volunteer Coordinator (2015 - Present)
FRC Robot Inspector (2012 - Present)
FRC 1241 - Alumni & Mentor (2007-Present)
Unread 08-01-2007, 19:28
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Motor with a built in Potentiometer..?
Adding a potentiometer to one of the kit motors is legal, and a very good idea if you're interested in being able to automatically control the position of your arm. Using a motor that is not in the kit is not legal.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2007, 19:29
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
If you mean to modify the motor itself that is not allowed, but if you want to add the potentiometer into your system that could have great...potential.
Unread 08-01-2007, 19:30
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
I believe this is addressed in <r46> in the manual. If the motor type is not included in the KOP then its illegal
Championship - Delphi "Driving Tomorrows Technology"
Unread 08-01-2007, 22:03
Kaushal.K's Avatar
Scouting & Things
AKA: kkaboose
Thanks guys.. big help.. =D
Unread 09-01-2007, 08:31
You may couple a pot to the motor shaft, you may couple a pot to the mechanism, you may use an encoder in place of the pot for each of these applications or you may use a microswitch to sense position(s). You may not modify the motor except to modify the mounting under the rules.
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
Help with window motor HWRobotics Motors 15 11-02-2004 02:43
Help with motor rpm/torque Wayne C. General Forum 2 26-01-2004 11:31
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
What with the small motor? Robb Gerber General Forum 10 10-01-2002 14:10
