Go to Post Girls, if you are techy, great! If you're not, don't worry about it. We're all good at something and FIRST can show you what that is. Just remember, be true to WHO YOU ARE. - Erin Rapacki [more]
Unread 08-01-2007, 20:09
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Connect COP wheels to Gearbox
Is there a standard fitting for connecting the KOP (not COP) wheels to the new planetary gearbox?
Phil Malone
http://www.GEARSinc.org
Unread 08-01-2007, 22:11
Back after 4 years off
FRC #5279
Re: Connect COP wheels to Gearbox
Typically you would want to attatch a sprocket to the gearbox and a sprocket to the wheel and then use chain between them.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 08-01-2007, 23:11
PhilBot's Avatar
AKA: Phil Malone
Sure, but why be typical?
The ratio is pretty good without the added chain reduction... I just wondered if it was possible to drive the new KOP wheels directly from the transmission with the various adapter that come in the kit.
The appeal of eliminating two gears and a chain is pretty high.
Phil.
Phil Malone
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Wheels & Gearbox Source team222badbrad General Forum 12 05-06-2006 16:17
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
