Go to Post Not joining as a freshman was the worst mistake I have ever made. - ProgramLuke [more]
Unread 08-01-2007, 23:08
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Re: How to update hex?
Also when I use MP Lab I need a .asm file! what do I do?
Unread 09-01-2007, 09:49
In MPLab look under
Project -> Select Language Toolsuite
Make sure "Microchip C18 toolsuite" is selected.
Unread 09-01-2007, 10:34
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
When you are using fusionEdit you need to set the location of the compiler/linker/Loader ect.
Edit>Project Properties
defaluts:
Complier Path:C:\mcc18\bin\mcc18.exe
Complier Args:-p=18F8722 "SourceFile" -fo="ObjectFile" /i"C:\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Linker Path: C:\mcc18\bin\mplink.exe
Linker Args:/l"C:\mcc18\lib" LinkerScripts ObjectFiles LibraryFiles /o"OutputFile"
Loader Path: C:\Program Files\Intelitek\EasyC for FRC\Loader\iLoader.exe
Loader Args:/D=HexFile /T /B=1 /C=18F8722 /V /H
Eric Haskins KC9JVH
Hex vs. Key alysume Technical Discussion 12 31-05-2006 22:37
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
