Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 08-01-2007, 18:53
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Stablizing the goal.
Field interaction - ROBOTS may push or react against any elements of the field, provided
there is no damage or disruption of the field elements. ROBOTS may not grab, grasp,
grapple, or attach to any field structure. If a ROBOT violates this rule, the head referee will
give one warning. If the referee determines that the TEAM is disregarding the warning, their
ROBOT will be disabled for the remainder of the match.
Say you had two pieces of some type of material to stick in between the legs to control the rate at which it could swing? Would this be considered against the rules?
Unread 08-01-2007, 18:57
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Stablizing the goal.
The said action would not be technically considered graping grasping or attaching to the goal but you may want to check with the Game Design Commitee
-Dustin Benedict
Unread 08-01-2007, 19:24
FlyingDutchman FlyingDutchman is offline
FRC #1566
FlyingDutchman will become famous soon enoughFlyingDutchman will become famous soon enough
well personally i dont know but i would assume that you could not
Unread 08-01-2007, 19:27
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
It sounds like what your suggesting is simply pushing on the spider legs from different sides, in which case I see no reason why you couldn't do that.
Unread 08-01-2007, 19:31
Danny McC's Avatar
AKA: Danny McCanney
No. I was assuming that the spider legs would be shaking the whole time. For some people that would make it difficult to score. I was asking if you could use two pieces of material to slow down the movement
Unread 08-01-2007, 21:38
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
I am assuming that contacting the spider leg at more than one point will be considered grasping it, making the stratigy of slowing its motion with two pieces illegal. This however brings up the issue of how contact at one point will be viewed as well as having say a three fingered manipulator surrounding the spider, limiting its motion but not actulay controling it.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 08-01-2007, 21:53
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
I have to admit that I have been reading these forums for a long time but have only recently begun posting. I say this only because in situations like this I find it more useful for someone to come with an answer or not come at all. I'm not saying that I know it all but somebody has a definite answer for this so let's let them get there reply in towards the top so people like me who actually need the answer don't have to sift through all of the assumptions.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Unread 08-01-2007, 21:58
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
The interpretation of rule G33 is going to be critical to some teams that have already referred to this type of design. I don't see how they will determine a grasp vs general contact; will it impede the spiderleg's motion along 2 axis or 3? If it impedes the spiderleg's motion along 3 axis - it's clearly a grasp/grapple, but restaining it along just 2 axis? I know how I would like to see it interpreted but this question will need a precise clarification from the game design committee. So we wait.....
Unread 08-01-2007, 23:32
TrippyMohan's Avatar
TrippyMohan TrippyMohan is offline
Sweetness
AKA: Jake
FRC #0573 (MechWarriors)
TrippyMohan is on a distinguished road
Send a message via AIM to TrippyMohan Send a message via MSN to TrippyMohan Send a message via Yahoo to TrippyMohan
It sounds to me that you are suggesting leaving a part of the robot there to jam the legs. I think this would be highly illegal, as we have never been able to completely detach any part of the robot.
I apologize if I misunderstood you.
email me?
Unread 09-01-2007, 15:18
KitKat89's Avatar
KitKat89 KitKat89 is offline
The Blonde in Charge
AKA: Kat Henry
FRC #0888 (Robotiators)
KitKat89 is an unknown quantity at this point
Send a message via AIM to KitKat89 Send a message via MSN to KitKat89 Send a message via Yahoo to KitKat89
So, what is the general consensus on just pushing a spider foot for stablization?
Unread 09-01-2007, 16:12
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
I think just running into the spider legs is legal but according to the rules you can't have somethin especially to hold onto the spider legs and stabilize it
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 09-01-2007, 17:38
thefro526's Avatar
Mentor for Hire.
It would not hold onto the legs. It would just be there so that it could bounce back and forth so you could slow the swinging rate
-Dustin Benedict
How far is the furthest you've hit the goal? Jared Russell Technical Discussion 2 07-02-2006 00:34
pic: The Predator - 294 - Capping the center goal Daniel Brim Extra Discussion 2 01-03-2005 13:06
pic: Got the ball and the goal CD47-Bot Robot Showcase 3 12-07-2004 22:08
pic: 16 placing the 2x ball on the stationary goal CD47-Bot Extra Discussion 4 30-03-2004 12:37
