Go to Post Even worse, you could have a "Kiss the Paul" contest. I heard he squeals when you pick him up too. - AndyB [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2007, 23:02
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
How Do Mecanum Wheels Work?
Hey guys, I wanted to know if anyone knew exactly how mecanum wheels work. How would the wheels have to be propelled in order to move side to side, foward and backwards, and still turn 360 degrees.
thanks,
Marko,1688
Unread 08-01-2007, 23:08
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: How Do Mecanum Wheels Work?
thanks,
Marko,1688
lets say these numbers represent the wheels, the top being the front
1______2
________
________
________
________
3______4
to go forward or backwards rotate 1 and 3 opposite of 2 and 4.
to go side to side, have 1 and 2 rotate in opposite direction to 3 and 4
to rotate in place, all same direction.
Unread 08-01-2007, 23:21
1______2
________
________
________
________
3______4
It's actually (using above diagram):
Forwards/backwards: all wheels same direction (as with tank steering)
Rotate in place: 1 and 3 one way, 2 and 4 the other.
Side to side: 1 and 4 one way, 2 and 3 the other.
We've done experiments with these, and this is how we did it.
Unread 08-01-2007, 23:23
zander_108's Avatar
AKA: Zander Guerra
I meant with the type of mecanum where the wheels face out from the center, at the corners, where the axis of the wheels are perpendicular... sorry for the missunderstanding.
Unread 08-01-2007, 23:26
I meant with the type of mecanun where the wheels face out from the center, at the corners... sorry for the missunderstanding.
That's actually better known as an omni drive.
For more information, this thread discusses one of the best mecanum drivetrains out there. The sides may be mirrored, which will not really affect directions (other than side to side)
Unread 08-01-2007, 23:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Through the angeled rollers, a Mecanum wheel diverts the force of the wheel into a different direction. The resultant force of the wheel depends on the angle of the rollers (which is typically 45deg).
For more detailed info, consult the following:
http://www.araa.asn.au/acra/acra2002...eter-Tlale.pdf
http://www.chiefdelphi.com/media/papers/1836
Unread 08-01-2007, 23:31
zander_108's Avatar
AKA: Zander Guerra
I acctually meant somewhat like this robot
Unread 08-01-2007, 23:33
SPARKY1688's Avatar
AKA: Marko Rajacic
Quick response thanks alot big help
marko
Unread 08-01-2007, 23:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That is a Holonomic drive. Holonomic platforms are not the same as Mecanum, although both allow for movement in all planar directions, rotation, and near-instant change of direction.
Unread 08-01-2007, 23:39
COACHTJ1688's Avatar
COACHTJ1688 COACHTJ1688 is offline
-STICKSHIFT ROBOTICS-
AKA: TJ
FRC #1688 (Stickshift)
COACHTJ1688 is an unknown quantity at this point
Thanks for the info guys. We appreciate it.
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
COTS Mecanum Wheels kmcclary Technical Discussion 1 10-01-2006 17:17
Improved Mecanum Wheels techtiger1 Technical Discussion 23 08-10-2005 01:02
