Re: pic: Height on top of a tube
I have a funny feeling that the GDC did not have this in mind when designing the game... Very interesting use of the field elements. But this also brings the question if the tubes will be filled up enough to carry the weight like that, and if the tube pops will you get a penalty?
If this were legal then it would be possible for all three robots on an alliance to be suspended at the same time. It is pretty clear by the scoring rules that this is not possible.
We took plywood and three mentors on a tube and it didn't pop. That would be pretty close to the weight of 3 robots but it was less then 4 inches.
I think the tube is concidered part of the field elements, but if it isn't it would be great to see the use of this tactic.
We thought of this today before we left and i tend to think that they are going to consider the ringers game elements, and if you could do this i guarantee there is going to be a tube popped too often for them to let it continue. Though they seem strong enough to hold the weight of the robot when the bottom is flat has anyone tried putting between 100 and 120 lbs. of force onto a sprocket or other object that is likely to stick out from the bottom, and see whether it pops.
#7
I wonder if propping yourself up on two of these would be considered "herding" or being "in posession" of two ringers? Gut instinct says that they are considered part of the field anyway. |
#9
i recall reading a rule in which it referred to the tubes as scoring objects and not part of the field...let me see if i can find it
#10
If 3 mentors were on TWO tubes laid side-by-side, would they be higher than 4 inches then? |
#11
Sad thing is, it's true. |
#12
As per team update #1
Hmm, now what? |
#13
<G08> Obtaining GAME PIECES - ROBOTS may obtain GAME PIECES via any of the following methods:Accepting a KEEPER prior to the start of the match as detailed in Rule <G04>Picking up RINGERS from the opposing ALLIANCE HOME ZONE that were placed there prior to the start of the match Grasping RINGERS or SPOILERS that have been placed in the CHUTE by the HUMAN
PLAYER Picking up RINGERS or SPOILERS from the playing field surface Removing a SPOILER from a HANGING position on the RACK if a tube is a field element then you could not grab it. do to rule G33> Field interaction - ROBOTS may push or react against any elements of the field, provided there is no damage or disruption of the field elements. ROBOTS may not grab, grasp, grapple, or attach to any field structure. If a ROBOT violates this rule, the head referee will give one warning. If the referee determines that the TEAM is disregarding the warning, their ROBOT will be disabled for the remainder of the match. So the tube is a game piece and would fall under those rules and not the element rules. So if you drop one tube on another, that is not herding because you only had one tube on your robot at a time. then if you climb on one tube you still have not touched both tubes this will get you up over the 12" unless they make a new rule I think this would work. "Sorry did not look at the update" Last edited by Mike Norton : 10-01-2007 at 13:01. Reason: update |
#14
7.3.6 Not allowed to sit on tube. almost every team hates to hear this ![]() |
#15
Oh well. ![]() |
| Tube Dimensions | JohnBoucher | Kit & Additional Hardware | 5 | 18-01-2007 22:16 |
| Vacuum tube. | Eric Scheuing | Kit & Additional Hardware | 11 | 13-01-2007 14:04 |
| pic: Top Gun Top Wheels | Rick TYler | Robot Showcase | 4 | 04-02-2006 11:13 |
| pic: 3/4 of our full height | Matt_Kitts | Robot Showcase | 2 | 23-02-2005 12:20 |
| Dimension Wanted - BOM Caster: floor to top plate surface height | kmcclary | Kit & Additional Hardware | 2 | 28-01-2004 12:02 |
