Go to Post Well, are comedy and sarcasm COTS items? - Karibou [more]
Unread 08-01-2007, 23:20
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Please help; HUGE mplab problem
I have no source files!
I took the FRC default code but I have no source files so I cannot build!! It only accepts .asm format, of which I have no files.
Unread 08-01-2007, 23:26
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Please help; HUGE mplab problem
What do you mean you have no source files...
go to kevin.org/frc
and download a version of the code that suits your needs (probably camera_s_2.zip).
Unzip that to a low leve directory (c:\code\) and then in mplab open project
and select the project in that directory.
Tell me how that goes
Unread 08-01-2007, 23:58
see it gives me this error:
Make: The target "C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\main.o" is up to date.
Make: The target "C:\Code\Robotics.cof" is out of date.
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "18f8722.lkr" "C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\main.o" "C:\Code\FRC_alltimers_8722.lib" "C:\Code\FRC_library_8722.lib" /o"Robotics.cof" /M"Robotics.map"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find definition of symbol 'Process_Data_From_Local_IO' in file 'C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\main.o'.
Errors : 1
BUILD FAILED: Mon Jan 08 20:58:20 2007
Unread 09-01-2007, 00:30
Kevin Watson's Avatar
La Caņada High School
FRC #2429
MPLINK 3.90, Linker
Errors : 1
MPLAB has problems with paths to build directories that are too long and (if I remember correctly) include spaces. Try moving your build directory to something like c:\frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 09-01-2007, 00:50
Ok I have no idea what is going on:
Now i get this;
Make: The target "C:\Code\main.o" is up to date.
Make: The target "C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\ifi_startup.o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\ifi_utilities. o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\user_routines. o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\user_routines. c:168:Warning [2066] type qualifier mismatch in assignment
C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\user_routines. c:191:Warning [2066] type qualifier mismatch in assignment
C:\Documents and Settings\Achuta\Desktop\FRC_DEFAULT\user_routines. c:193:Error [1203] too few arguments in function call
Halting build on first failure as requested.
BUILD FAILED: Mon Jan 08 21:49:59 2007
Unread 09-01-2007, 01:25
FRC #2429
Now i get this;
The first two warnings are related to calls to printf() and the error, I'm guessing, has to do with a call to Generate_Pwms().
To fix the problem, go to this dialog box: Project->Build Options->Project->MPLAB C18 Tab
Once you're there, click on the "Use Alternate Settings" check box, and then add "-nw=2066 -D_FRC_BOARD" to the end of the stuff in the associated text box. When done, it should read "-Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD" (without the quotes).
-Kevin
Kevin Watson
http://kevin.org
IFI_Loader Problem, please help. winners Programming 9 18-01-2006 17:54
BIG Problem, please help me!! Srkasner FIRST Tech Challenge 2 11-01-2006 12:45
gearing problem. Help please! camsrobotics Motors 9 22-01-2005 20:45
PLEASE HELP US FIND OUR MOMMY (or MPLAB) superlou Programming 3 23-02-2004 16:33
BIG PNUEMATIC PROBLEM NEED HELP PLEASE!!!! archiver 2001 1 24-06-2002 00:30
