Go to Post Being involved with FIRST is a privilege, not a right. - Katie Reynolds [more]
View Poll Results: What is the approach angle of your ramp (floor to ramp)
< 10 degrees 15 10.00%
10 to 15 degrees 36 24.00%
16 to 20 degrees 65 43.33%
21 to 25 degrees 21 14.00%
26 to 30 degrees 9 6.00%
> 31 degrees 4 2.67%
Voters: 150. You may not vote on this poll
Unread 09-01-2007, 00:23
SkiMasterATV's Avatar
SkiMasterATV SkiMasterATV is offline
AKA: Bryan Andrews
FRC #2046 (Tahoma Robotics Club)
Team Role: Driver
SkiMasterATV is just really niceSkiMasterATV is just really niceSkiMasterATV is just really niceSkiMasterATV is just really nice
Ramp Angle Survey
I am a member of a rookie team, and we are just curious about the approach angle of the ramps that are being built out there. Supposedly 60% of the teams polled in a recent survey said that they would be allowing both alliance partners to get on to them for 30 points apiece.
The poll is found here
If so many people are focusing on ramp construction, and if you will have one, we are just curious as to what your floor-ramp angle will be, and what set of points are you going for...
The hope is that an average approach angle can be achieved and be used in the planning of our design.
Any help would be greatly appreciated. Thanks in advance.
-Bryan/2046
Unread 09-01-2007, 00:30
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: Ramp Angle Survey
We were thinking of around a 19 degree ramp... Using the four foot weight class this is about the smallest angle we can achieve reasonably. I really think it will be easy for robots to get on our ramp though, using material with nice traction... And a couple other things ;p
Unread 09-01-2007, 00:42
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Our potential ramp (which we were thinking about scrapping) would have angle of about 20%.
Unread 09-01-2007, 00:43
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
It's reasonable to assume that most robots this year with have a higher CG than last year. About half last year didn't even try to go up the 30 degree ramp. With this in mind, 15(ish) degrees should be the maximum to accomidate most robot designs. Any higher, and you'll have a lot of flipping.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 09-01-2007, 09:19
GaryVoshol's Avatar
Cogito ergo arbitro
How do you figger, Dan? This year's robots won't have a heavy shooter up on top. (OK, some robots had their shooter mounted low, but most were high.) I presume whatever ring-handling mechanism you have will be less massive than a shooter, could be folded up into its starting configuration when going up a ramp.
I'm not saying it's a trivial matter. I just think it will be easier this year, as long as you plan ahead. There's heavy stuff you need (battery, drivetrain, [optional] pneumatics) that you can put in your base which can counterbalance your vertical mechanism.
If you're going for a fixed 6-foot design, you would have more tipping issues.
The original poster is correct in considering the approach angle problem (and don't forget the trailing angle as well). Bumpers hang out significantly from your wheelbase - don't forget them in your calculations. I certainly hope we don't see any of the leading-angle-trimmed-off bumpers that some competitions allowed last year. That's not fair to those teams that follow the rules.
(since 2004)
Unread 09-01-2007, 09:52
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
If you have a robot with 4wd tank steering and a 30" wheel base, the maximum ramp angle you can achieve before you bottom out (with 2" ground clearance) is only a 7 degree ramp! (This is looking at when the robot gets to the top of the ramp and is going over that corner).
This is obviously a round about number and i didn't do any special calculations for it, but still it gets the point across.
So, you would need a ground clearance of about 4.3" if the ramp was 16 degrees (the angle I have been looking at for a ramp design). Again this is 30' wheel base and 4wd.
To make getting up a ramp easy, just make your robot 6wd and you should have no problems.
By the way, does anyone know the angle of the ramp 111 (wildstang) used in their 2001 robot?
Edit:
Oh, and if your robot's CG is 48 inches above the ground and in the middle of your robot (with your robot orientated so it drives where the short side is the front), you would tip over if you attempted a ramp of 18 degrees or more. I highly doubt that any robot will have a CG at 48 inches but I always look at worst case cenario.
P.S.
Please correct me if im wrong. I did these calculations in about 10 seconds using simple triangles.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-01-2007, 13:30
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
The real issue with getting up ramps is as the above posters have pointed out is getting hung up as you go up over the top. The best solution for this is really just making a 6 wheel robot. There are very, very few situations where a 6 wheel robot going pretty straight up a ramp can get stuck. The reason is that the center of gravity or balance point of the robot is over a wheel. If the robot is caught on one of the points between the wheels it will usually tip to one of its wheels and maintain traction.
Team Website
Unread 09-01-2007, 14:05
Brandon Holley's Avatar
If your going to have a ramp, it is quite feasable to build one with a small degree....you have 4 feet of height to work with (in the highest weight class)
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 09-01-2007, 14:10
DjAlamose's Avatar
AKA: Teh Albie
asin(12/48)=14.47751218592992 deg
This is the smallest angle that you can acheive without doing any extentions.
Also, this really isn't feasable because you wont be able to get that 48" long piece, you would need some ground clearance.
So what I've been using:
asin(13/45)=16.79144711458869 deg
13 because I want to make sure that we get that 30 and not 15 for being 11.8" above the ground, and 45 because it gives a 3" ground clearance.
2004 GLR Champs
Unread 09-01-2007, 14:31
hmmm...i was thinking more along the lines of not one solid piece of metal, maybe your ramp has a joint????
Unread 09-01-2007, 14:34
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
How about a ramp on a 20 degree angle. If you want your robot to be lifted then please be able to drive up an incline of at least 20 degrees.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 09-01-2007, 14:38
DjAlamose's Avatar
AKA: Teh Albie
Nope, one solid piece. Of corse this is still in design and we aren't even sure this is the route we want to take.
Oh, and by the way, a sheet of aluminum diamond plate 24x48x(1/16) weighs only 7.056 lbs (yeah thats alot of weight, but holes can be drilled....Lots of holes....)
2004 GLR Champs
Unread 09-01-2007, 15:12
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by DjAlamose View Post
... 13 because I want to make sure that we get that 30 and not 15 for being 11.8" above the ground, and 45 because it gives a 3" ground clearance.
What about bumper clearance?
(since 2004)
Unread 09-01-2007, 15:15
DjAlamose's Avatar
AKA: Teh Albie
Rule R37 comes into play.
STANDARD BUMPERS must remain within the BUMPER ZONE when the ROBOT is resting on the floor in PLAYING CONFIGURATION. They can not be articulated or moved outside of the BUMPER ZONE. The one exception to this is STANDARD BUMPERS may be within or below the BUMPER ZONE during the END GAME if the ROBOT is in its HOME ZONE (see Figure 8-3).
So durring end game, they just fold down and out of the way.
2004 GLR Champs
Unread 10-01-2007, 09:15
Assassin Shadow's Avatar
Assassin Shadow Assassin Shadow is offline
Inventor of the Shadow-gram
AKA: James Bilger
FRC #0342 (The Burning Magnetos)
Assassin Shadow is a jewel in the roughAssassin Shadow is a jewel in the roughAssassin Shadow is a jewel in the rough
Forgive me if I'm wrong, but does it really matter whether the robot is up past the ramp. It doesn't have to be past the corner at the top of the ramp to earn points, it just has to be at least 4 inches up the ramp. So in a worst case scenario, just make it so that your robot can make it that far up a ramp and then turn a little sideways so that they don't roll back down. Viola!
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Angle of Launcher ThisGuyRight Rules/Strategy 3 24-01-2006 11:05
Angle from X,Y Astronouth7303 Programming 18 19-04-2004 22:08
The angle of going up the Ramp David Bryan Programming 2 21-01-2003 20:56
