Go to Post The first team that uses a lawyer to interpret the rules should be disqualified from all competitions, just on general principles. - dlavery [more]
Unread 09-01-2007, 12:02
dwc309 dwc309 is offline
FRC #1552
dwc309 is an unknown quantity at this point
Will there be new code for the '07 competition
Will there be any new code provided for the '07 competition?
Unread 09-01-2007, 12:37
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Will there be new code for the '07 competition
My understanding is that IFI will not be updating their code and Intellitek has released a new version of EasyC. If you're referring to my camera code, I may release an update that changes some code in tracking.c/.h, but I haven't decided yet. The code posted to my website should already find the light(s) for you, but there are some changes (a few tens of lines of code) that can be made to help you determine the location of a peg/spider leg. With my code, you're 98% there already, I'm hoping there will be much discussion here on how to best navigate to the nearest peg/spider leg (you guys have to do some of the engineering <grin>).
-Kevin
Kevin Watson
http://kevin.org
Unread 09-01-2007, 13:25
bcieslak
Posts: n/a
OH No Kevin,
Don't give away to much of the game....
As an exercise for my new programmers I had them flowcharting your original code to learn the structure and how it works. Our cameras are up and running on the FRC controller and the EDUbot.
I still have'nt quite figured out how to track multiple targets yet, though. THe nearest I can figure is the camera will box off multiple masses and locate the center of gravity of all those masses. But how to identify individual masses within the same field of view is still a mystery.
BrianC
QUOTE=Kevin Watson;552130] If you're referring to my camera code, I may release an update that changes some code in tracking.c/.h, but I haven't decided yet. The code posted to my website should already find the light(s) for you, but there are some changes (a few tens of lines of code) that can be made to help you determine the location of a peg/spider leg. With my code, you're 98% there already, I'm hoping there will be much discussion here on how to best navigate to the nearest peg/spider leg (you guys have to do some of the engineering <grin>).
-Kevin[/quote]
Unread 09-01-2007, 13:59
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
You can also find a way to get to the spider leg where you don't have to rely soley on the camear *wheels turning*.
Unread 10-01-2007, 11:52
FRC #1552
Kevin,
You are such a slave driver. <g>
Thanks again for all you do.
don clay
Is there a manual for the new default code somwhere? Anton Programming 1 16-01-2005 16:34
pic: 121 was there. Where was the competition! CD47-Bot Extra Discussion 3 19-04-2004 15:48
Will there be a BOM this year!! D@ve General Forum 2 14-12-2003 11:23
Will There Ever Be Negative Scores? Joe Matt General Forum 30 18-01-2003 17:15
There will be goal(s)! Dr.Bot Rumor Mill 48 22-12-2002 09:03
