Go to Post Congrats! You are an inspiration to us all! - preussrobotics [more]
Unread 09-01-2007, 12:57
Roni2230 Roni2230 is offline
FRC #2230
Roni2230 is an unknown quantity at this point
Are Both Starting Footprint Orientations Legal?
I have a question about this year's robot dimentions.
The rules indicate that the robot should be 96.52x71.12cm. So, can I build a robot that's 96.52cm on the front and 71.12cm on the side? Or does it have to be 71.12 on the front and 96.52 on the side?
Unread 09-01-2007, 13:01
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Robot dimentions
Either way, as long as you are talking about the Length and Width dimension which I am sure you are.
Some prefer to make a long narrow bot, while others prefer to make a wide short robot.
There are advantages and disadvantages to each. (Turning radii, Chain length to power wheels, etc. etc.)
Good luck!
Unread 09-01-2007, 14:21
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Are Both Starting Footprint Orientations Legal?
The only thing to take into consideration is that your robot must start the match with its long direction pointing towards the center of the field. So if you did make a wide short bot, then it would be facing the side of the field at the start of the match.
Edit:
Nvm, <G29> deals with Flop down robots.... My bad
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-01-2007, 14:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Can you provide the rule number and its text, please? It's helpful to everyone to back up your statements with information directly from FIRST. Thanks.
--Madison--
...down at the Ozdust!
Unread 09-01-2007, 14:30
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I don't remember reading that.
Unread 09-01-2007, 14:33
DjAlamose's Avatar
AKA: Teh Albie
<G29> ROBOT orientation - ROBOTS must start the match with their long (maximum) dimension in a vertical orientation. After the start of the match, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R37> in Section 8 to determine how this affects the use of bumpers.
There you go.
edit:
nvm, im reading rules wrong again, this means flop down >.<
2004 GLR Champs
Unread 09-01-2007, 14:41
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
My only caution to people considering a wide robot is to keep in mind that a wide robot may make it much more difficult to climb up onto a ramp robot for 30 points at the end of the match.
Matt B.
Unread 09-01-2007, 14:42
edit:nvm, im reading rules wrong again, this means flop down >.<
A great example which used to be legal, and now is not as you have stated was Team 19 in 2003.
They started standing up and to gain full width advantage, fell over and made their (starting) height (60") their width when driving.
It was a great strategy for a couple reasons, but there was always a safety hazard involved, and also a field damage issue.
This was outlawed in 2004/2005 I forget which.
Unread 09-01-2007, 14:46
Madison's Avatar
FRC #0488 (Xbot)
Elgin,
The way I read it, the rules this year allow for robots that fall over at the start of the match.
--Madison--
Unread 09-01-2007, 14:52
DjAlamose's Avatar
AKA: Teh Albie
It was outlawed last year due to (what I belive) nuemerous safety issues with shooters. But it has been reintroduced and G29 covers that.
2004 GLR Champs
Last edited by DjAlamose : 09-01-2007 at 15:36. Reason: sigh, today is not a good day
Unread 09-01-2007, 15:00
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I looked quickly through the handbook, and I thought I saw that rule but I wasn't sure. So I've been looking through the Robot rules to find it. And now I know! It's under the game rules!
Okay, so flop-bots are legal? I bet HOT is happy
Also, what are we supposed to do about bumpers and flags should we decide to use a flop-bot? Does the flag start horizontal? And are flop-bots allowed to have bumpers?
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 09-01-2007, 15:07
DjAlamose's Avatar
AKA: Teh Albie
Part of rule <R37>
STANDARD BUMPERS must remain within the BUMPER ZONE when the ROBOT is resting on the floor in PLAYING CONFIGURATION. They can not be articulated or moved outside of the BUMPER ZONE. The one exception to this is STANDARD BUMPERS may be within or below the BUMPER ZONE during the END GAME if the ROBOT is in its HOME ZONE (see Figure 8-3).
So the bumpers are now regulated in your playing configuration, not your starting configuration.
2004 GLR Champs
Unread 09-01-2007, 15:09
GaryVoshol's Avatar
Cogito ergo arbitro
Why didn't you read the rest of the rule while you were right there? It refers you to the bumper rule for how flop-bots can have bumpers. (Although there is very little specifically said.)
(since 2004)
Unread 09-01-2007, 15:24
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
It was outlawed last year due to nuemerous safety issues with shooters. But it has been reintroduced and G29 covers that.
Can you provide a specific reference or document that shows that flop-down robots were "outlawed last year due to nuemerous safety issues with shooters"? I do not recall that that, or any other, specific reason was ever published. Do you know this for sure?
Making up information and hoping that others will accept it as fact helps neither you nor the person seeking knowledge. If you don't KNOW the answer to a question, it is usually better to remain silent than to provide a made-up, incorrect answer. No information is better than bad information.
-dave
Unread 09-01-2007, 15:37
DjAlamose's Avatar
AKA: Teh Albie
Dave
Yes I will say that the "due to numerous safety issues" was an addition on my part. But this is what I believe to be as the reason this happened. Also, I would provide an exact rule stating that flop downs were illegal last year if I could find a copy of last years manual.
Sorry for any confusion.
Edit:
I found where in the rules last year where it stated no flop downs
<G17> ROBOT Orientation - ROBOTs must maintain their vertical orientation with respect to their starting position throughout the match. ROBOTs may not intentionally tip over onto one of their initially vertical sides and operate with this side parallel to the ground. “Flop-Down” robots will be disqualified.
found here:
http://www.chiefdelphi.com/forums/sh...ight=flop+down
Remeber this rule is from last year!!!
2004 GLR Champs
Are Capacitors Legal? mechanicalbrain Electrical 32 22-11-2005 21:06
physics and engineering are both cool charlie_grr Math and Science 2 03-06-2003 21:46
NYC-FIRST Workshop are starting Rich Wong General Forum 1 10-10-2002 09:38
Are these mat'ls legal? archiver 2000 1 24-06-2002 00:15
college orientations Lora Knepper Chit-Chat 5 18-07-2001 17:28
