Go to Post While many teams like to go fast, only a select few do it well. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 09-01-2007, 16:44
rob_szma1212 rob_szma1212 is offline
FRC #1027
rob_szma1212 is an unknown quantity at this point
Transmissions
Team 1027 might want to use last year's transmission case, but they can not be bought anymore. If your team has some we are interested in them.
Thanks,
Rob
Build Team Captain for team 1027
Unread 09-01-2007, 16:53
Billfred's Avatar
Billfred Billfred is online now
Re: Transmissions
Thanks,
Rob
Be careful, you may want to check the manual on this one. The requirement is for the item to be available to all teams, which no longer appears to be the case.
Unread 09-01-2007, 16:58
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Transmissions
Normally, I'd suggest that you post on CD-swap. In this case, look at this thread...there are legality issues with using last year's gearboxes, since they are no longer COTS.
Unread 13-01-2007, 16:38
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Re: Transmissions
Where can we purchase 2007 Transmissions?
Unread 13-01-2007, 16:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Transmissions
http://www.banebots.com/c/FIRST
Unread 13-01-2007, 16:56
Windward's Avatar
FRC #1452
Re: Transmissions
Thank you. Also, where can we purchase the allen head screws for the transmission? We were unable to find them on the BaneBots website. Thanks again.
Unread 13-01-2007, 16:57
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Re: Transmissions
You may also want to consider the AM single speed transmission, similar to those included in last year's kit and legal for this year's game.
http://http://www.andymark.biz/am-0011.html
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 13-01-2007, 17:54
cgdtgurl07 cgdtgurl07 is offline
drive train/ mechanic
AKA: Autumn
FRC #1741 (Red Alert)
cgdtgurl07 is an unknown quantity at this point
Send a message via AIM to cgdtgurl07
Re: Transmissions
www.ifirobotics.com also may have some useful parts.
Transmissions Nitroxextreme Technical Discussion 29 13-04-2006 23:37
Transmissions Starke Technical Discussion 16 19-04-2005 10:13
Transmissions Jedi Padawan Technical Discussion 3 18-01-2004 23:38
Drill Transmissions Mr Pirozzo OCCRA 1 16-09-2003 23:06
Drill transmissions camtunkpa Technical Discussion 3 12-05-2003 21:21
