Go to Post Don't like it? Then lets change the culture. - Barry Bonzack [more]
Unread 09-01-2007, 19:35
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Problem with BB gearbox spacer
When we attached our two BB gearboxes to CIM motors, one made a loud skreeching noise.
Upon examination it turned out that the black metal spacer that goes between the CIM motor and the pinion gear was ~ 1mm too long. A quick trip to the bench grinder fixed the problem, and the gearbox runs smoothly now.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 09-01-2007, 20:37
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Problem with BB gearbox spacer
What is the dim of the spacer now that you cut it down by 1mm?
Will anyone who has successfully run the CIMs with the BB 56mm trans please measure their spacers and post the dimension on this thread?
If we get some good data, we can perhaps have FIRST or BB send out an all points bulletin with the news to check your spacers for the right dimension.
Joe J.
Team #88, TJ2
Unread 10-01-2007, 01:08
teamtestbot's Avatar
teamtestbot teamtestbot is offline
Prophet of ROFLCOPTER
AKA: charles
FRC #1771 (NGHS Robotics)
teamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the rough
Send a message via AIM to teamtestbot
Exclamation Re: Problem with BB gearbox spacer
Hi all,
The spacer I checked on one of the gearboxes did not have a 5/16" or 8mm keyed bore. Instead, it was much smaller, almost around the 1/4 or 9/32 range and would not fit on the shaft. I had to drill it to 5/16" and trim the key slightly to fit eveything in. I don't have access to the internals of that one any more, as putting it together and not having the thing seize or grind terribly (was not a spacer issue - appeared to be small manufacturing flaws causing everything to align in only one orientation) was a two hour ordeal!
The QC on the gearboxes seems pretty interesting to say the least. I hope they hold up under use.
FRC 1771 North Gwinnett High School Robotics, Founder & Alum 2007
pic: DeWalt Gearbox with two CIMs MAteo9944 Extra Discussion 17 02-01-2007 05:34
Gearbox problem? Kevin Ray Technical Discussion 1 22-02-2006 09:09
Nylon Spacer Size Laura 1547 Technical Discussion 2 22-01-2006 15:42
pic: Spacer....heh CD47-Bot Extra Discussion 4 15-03-2004 01:00
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
