Go to Post That inspector needs their hard drive wiped and the common sense upgraded from version dingbat 1.0. - Andy Baker [more]
Unread 09-01-2007, 20:37
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Why should I update my 2006 code?
It seems like all of the things Kevin kindly updated, I already did myself last season:
" Altered tracking algorithm to use the t-packet confidence value to
determine whether the code should track or search.
Added Get_Tracking_State() function, which can be used to determine
if the camera is pointing at the target."
" Provided two new functions to set the pan and tilt servo position.
This was done to provide a level of indirection so that the servos
could be controlled from the robot controller or the CMUcam2."
I saw that t-packet confidence could be useful, and added it to the if() in tracking.c before it romped off tracking the "target". I also don't need a Get_Tracking_State() as I just check to see if tpackets.my = 1 before I let it go go romping off tracking. And yeah, I noticed that some of the PWM values were fuzzy as well while testing. But, I just changed tracking.h around and got it to work fine.
" Fixed bug in search initialization code where temp_pan_servo was
initialized to zero instead of Tracking_Config_Data.Pan_Min_PWM."
Hmmm, didn't really have any problems with this.
Am I missing something huge here? Is there really any need to update?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Why Ref’s should always throw flags BLCamp Championship Event 8 11-05-2006 08:19
Master code update Eldarion Control System 1 09-03-2006 21:14
Why should Andy be on Survivor? George1902 General Forum 24 21-06-2004 01:19
What Features Should the Default Code REALLY include? Joe Johnson Programming 30 29-04-2004 22:39
Why I think FIRST should reconsider... Joe Johnson General Forum 36 14-01-2003 15:51
