Go to Post We considered naming our 2014 robot "Please Don't Point it at Me". I think the name fits. - KosmicKhaos [more]
Unread 09-01-2007, 21:16
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Nason Pressure Switch?
Originally Posted by eshteyn View Post
... I do not believe you need a pressure switch on tanks that are not filled up by the compressor ...
The compressor, whether mounted on the robot or not, is the only allowed means of pressurizing a pneumatic tank. Please read <R102>.
Richard Wallace
since 2003
Unread 09-01-2007, 21:48
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
team number 1717 wants to have one tank connected to a compressor and another charged before the match by the same compressor, but not recharged during the match. Because this cylinder will not be recharged during the match it does not require a pressure switch but it does require an emergency relief valve to keep pressure at the allowable level and make sure it does not go any higher when charging by the KOP compressor before the match.
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 21:56
Because this cylinder will not be recharged during the match it does not require a pressure switch ...
That is not correct. <R101> and <R102> are applicable to any compressed air storage; the rules explicitly cover the case of a tank that is charged before the match using an off-robot compressor.
Richard Wallace
since 2003
Unread 09-01-2007, 22:03
eshteyn's Avatar
I apologize, you are correct, all rules must be followed for filling the tank before a match same as filling a tank with an on-board compressor. Also i believe <r103> also applies to this situation.
Unread 09-01-2007, 22:15
Good catch; you are right about <R103>.
Richard Wallace
since 2003
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Urgent need for Nason pressure switch!! PLEASE HELP! haverfordfords Pneumatics 12 18-02-2005 02:04
Nason pressure regulator...HELP!!! Bob Steele General Forum 0 25-02-2004 16:08
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
