Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 09-01-2007, 18:11
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Think about Robot Ground Clearance
I wanted to give a plea to all teams:
Please have some ground clearance on your robots.
With up to 60 points in the balance based on robots climbing onto one another, it would be a smart design choice to give your self some clearance underneath your frame so that you can climb onto other 'ramp' type robots during the endgame.
In terms of numbers:
In the picture attached to this post 'a' is the ground clearance of the frame and 'b' is the distance from the front of the frame to the point where the wheel makes contact with the ground. For simplication, we can assume that 'b' is 1/2 of the wheel diameter.
Therefore, with only a 1" ground clearance with 6" wheels, you can climb onto a ramp that is roughly 19 degrees in grade (use arctan{a/b}).
So just to reiterate, please consider sacrificing at least one inch of ground clearance to make you more of a team playing robot that can climb onto ramps a bit easier!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
Virginia Tech http://www.me.vt.edu/romela
P.S. Feel free to contact me if you need any help with robot mechanisms (like cool four bar linkages!)
Unread 09-01-2007, 20:57
Trample-Bot Trample-Bot is offline
Master of The Rules
AKA: Logan Byers
FRC #1777 (West Vikings)
Trample-Bot is an unknown quantity at this point
Re: Think about Robot Ground Clearance
yes.....
if you have no possibility of lifting another robot... please, PLEASE, make sure you can climb at leats a 20 degree angle, or you willl just be a lump
My Other Car is a The Chariot
Unread 09-01-2007, 21:01
Andrew Blair's Avatar
FRC #0306 (CRT)
Has anyone thought that instead of teams catering to ramp/lifter teams, ramp teams should be catering to the people being lifted?
Although, I agree that in any case, a little ground clearance is always a good idea.
-Sir Francis Bacon
-Albert Einstein
Unread 09-01-2007, 21:04
Master of The Rules
AKA: Logan Byers
we are catering to the liftees, we are hoping to provide them with the lowest possible angle of inclination, but if their ground clearence is only 1/2", they are S.O.L.
Unread 09-01-2007, 21:11
Ian S. Ian S. is offline
FRC #1522 (D.O.T.M Robotics)
Ian S. is an unknown quantity at this point
Send a message via AIM to Ian S. Send a message via Yahoo to Ian S.
This year will take alot of teamwork between alliances, so we should think of all the other teams at our regional(s) before designing our robots.
I also think that ramp/lift/crane bots can only do so much to help the bots being elevated have an easy time. If a teams robot can make it up a 20-25 degree angle ramp, and you have enough ground clearance, the team should be fine for the competition.
D.O.T.M - Defenders of the Multiverse
2006 VCU Regional Finalists (thanks to team 345 & 384)
2008 VCU Regional Champions (thanks to team 345 & 1086)
Unread 09-01-2007, 21:15
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
A little clearance wouldn't hurt. There have been a lot of designs that drew a lot of criticism because the involved a ramp. Personally, I think if you going fast enough you can get up just about anything.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Unread 09-01-2007, 21:27
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I agree. Clearance would be nice, not only for getting up ramps but also for those who arn't thinking of ramps at all but lifters... Someone thats only 1/2 inch thick will probably not be able to stand 120lbs being supposrted by it.
Unread 09-01-2007, 21:28
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
If all of the teams would build bots capable of getting onto last year's ramped platform, there'll be no problem.
Madness?
THIS IS F.I.R.S.T!
Unread 09-01-2007, 21:48
Best Available Data
FRC #1778 (Chill Out!)
I'm confuzzled. I was just measuring our robot for last year, and it had 1/2 inch of ground clearance, and 4" wheels. It climbed the ramp extremely well with wedgetop tread. (Roughtop was different story altogether, becuase it wore out pretty much instantly spinning on lexan.) But we had six of them, does your math assume 4? (Your picture isn't showing up)
Unread 09-01-2007, 22:16
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Your wrong on that, if the wheels are placed out to the outer extreme of the frame it's possible for them to climb. Also i would like to ask all teams, please, please have at least a minimum of .5 inches of clearance under your robot(including bumpers). More than .5 inches is preferable but at least .5 including bumpers.
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 22:22
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Wheels placed at the outer extremes of the frame might cuase their chassis to get caught on the lip of the ramp if they don't have enough ground clearance.
Unread 09-01-2007, 22:26
Master of The Rules
AKA: Logan Byers
you have to watch out though.... my mentor was talking about how our robot could potentially be damaged by other robots going a mile a minute in the heat of the competition...
Unread 10-01-2007, 08:22
ggoldman's Avatar
FRC #0401
iCurtis:
My math just assumed that the front bottom edge of the frame formed a right traingle with the ground and the point where the drive wheel makes contact with the ground.
From my experiance with FIRST, most teams do not place their wheels on the extremeties of their frames, so this is applying to teams who have wheels inside the footprint of their frames.
See the *crude* picture below:
....................FRAME
.....l......*.................*
..a l.......*.....WHEEL..*
.....l.........*............*
.....l<------> ****.............------->x
..........b
a = distance from edge of frame to ground
b= distance (in the x direction) from edge of frame to contact point wheel makes with ground (assumed to be the radius of the wheel).
Hopefully this clears it up a bit!
Gabriel Goldman
PhD Candidate
Virginia Tech
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
Think about it Raul General Forum 8 07-04-2003 15:00
Is it illegal to lift another robot off the ground? Tton Rules/Strategy 19 14-01-2003 21:28
think about it E. The Kidd CD Forum Support 2 01-12-2001 22:16
