Go to Post I believe the employees of AndyMark should start making presentations to large companies on the right way to run a business. - Taylor [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2007, 19:15
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
How many targets?
For some reason, we have 4 packs of cold cathodes, with 2 bulbs and a transformer each. We have 2 white diffusion panels for the targets though, and the parts inventory says that we should have 8 target packs.
So, given the kit on the inventory, we should have enough to make two targets. Did we miss out on a pack of 4 packs?
Thankfully, we still have our target from last year.
Unread 07-01-2007, 19:46
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: How many targets?
The KOP list says 8. We got 4 packs, each with 2 lights. If that is the case then there is only enough for 2 lights. That should be enough for testing though. Maybe they will allow you to buy more at the same time as we can buy more tubes.
Unread 07-01-2007, 19:56
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
The kit came with 8 tubes, 4 per light in the hope that teams will be able to test the robots ability to choose between light A and light B during autonomous mode and score.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 07-01-2007, 19:59
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
They are referring to the number of tubes in the KOP. The should be enough to build 1 FIRST style target light.
Unread 07-01-2007, 20:14
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
You can order more from here. HDPE (the filter) can be ordered from mcmaster
Unread 07-01-2007, 20:33
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
The 8 in the KOP checklist refers to the number of cathodes. That is, 8 cold cathodes, and 4 transformers.
The other part that you need to make a target is the diffusion plate, of which there are 2 in the kit. In section 10.1.1 of the manual it says
Originally Posted by FRC 2007 manual
Two target light kits enabling teams to practice working with dual light targets
Unread 07-01-2007, 21:34
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
If you think about it, there is no angle at which you can see more than 2 of the lights at a time. Therefore i don't think FIRST thinks we need more than those yet. I believe they will be avalible for purchase through FIRST eventually, and they can be bought elsewhere.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 07-01-2007, 21:47
geeknerd99's Avatar
Fire Hazard
AKA: Daniel Lin
That's kinda weird. Are they halving the brightness of the lights this year then? Our light from last year has all 8 tubes in it.
Maybe that's why we were having trouble aiming last year...
Unread 07-01-2007, 21:55
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
The specs last year called for a target with 8 tubes. It seems like they reduced the number of cathodes in a target, at least for unofficial use.
Unread 07-01-2007, 22:20
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
i beg to differ... i believe that each target uses 8 tubes (4 transformers) per team target. you can see the design here that is one of the team drawings. also in the KOP section of the manual it says under kit evolution on pg2 "Two target light kits enabling teams to practice working with dual light targets" and since the team drawing has 8 tubes and thats what some teams got....we should get more so we can build 2 targets.
just my $0.02
/forest
Unread 08-01-2007, 12:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I just got off the phone with a FIRST rep about some missing parts. She said 8 tubes and 4 transformers were enough to build 2 lights. She also said the lights had 4 tubes each. This is obviously in direct contradiction to the field drawings posted by FIRST, so I'm hoping for some rapid clarification on this issue since replacement part ordering ends pretty darn soon.
Unread 09-01-2007, 21:26
Just got word from FIRST. There are 8 cathode bulbs per light, as per the drawings. So you should have recieved 2 white boxes, each containing 4 packs of bulbs and 4 transformers. I think they're being sent out to teams already.
Unread 09-01-2007, 21:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Are you saying that we are being mailed additional bulbs?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-01-2007, 21:59
I'm saying I was told they were mailing extra bulbs to teams. It's probably still smart to call and check to be certain.
Unread 10-01-2007, 20:29
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
the team update says there is a revision to the KOP checklist addressing the issue. i guess they just listed the wrong amount. if you are really in need of a second target, use the one from last year. it is the same to my knowledge.
how many of what? Hendrix Motors 1 11-02-2005 13:19
How many SD teams in 05? JP_1163 FIRST-related Organizations 0 01-10-2004 11:50
How many Attwoods? mike325 Technical Discussion 0 06-01-2003 17:43
How many robots? archiver 1999 1 23-06-2002 21:54
