Go to Post There are zillions more volunteers than paid staff. We are FIRST. - Rick TYler [more]
Unread 09-01-2007, 20:30
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
How to measure pressure in the tubes?
At this point, most teams probably have their tubes inflated (at least I hope so). However, I am unsure at to how many teams actually have them inflated to the right pressure.
My team inflated the tubes most of the way and we have been assuming it is correct. Unfortunately, we have been unable to figure out an accurate way of measuring the pressure inside the tube.
Has anyone had any success in this regard or had any ideas...
I think this is needed by most teams.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 09-01-2007, 20:40
Umm Errr...
Re: How to measure pressure in the tubes?
I didn't know FRIST specd a pressure.
I think you can pretty much rule out and sort of tire pressure or normal pneumatics guage. I doubt those things are inflated to even 2 psi.
You could always order a lower range pressure guage and use the fittings from a float inflator.
I suppose you could always put a piece of plywood on the tube with a weight on it and measure the squish. We noticed that by themselves, the tubes don't change much dimensionally with presssure.
1139 Alumni
Unread 09-01-2007, 20:49
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
If you hook up your robots compressor and pressure gauge, the tubing is just right to fit into the tube nozzle, pump until the gauge reads the pressure.
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 21:37
Will the guage read 2.5 PSI? From what I remember, it won't. Almost no "normal" guage (normal in the sense that it's commonly seen and/or used) will read that low.
Unread 09-01-2007, 21:43
eshteyn's Avatar
It depends what gauge you use, there are low pressure gauges.
Unread 09-01-2007, 21:52
DonRotolo's Avatar
Back to humble
FRC #0832
Exactly. Some gauges measure a max of, say 10 PSI. Perhaps an electronic pressure sensor, often sold as an accessory for a voltmeter, or something in the auto repair world, might be appropriate.
Anything qith a max scale of about 10 times the pressure you're trying to read will be horribly inaccurate.
To measure the pressure in a tube, connect some tubing (metal or plastic) to the inflation opening, connect that to the plastic tube and through the correct connectors to a gauge. A "T" fitting will allow inflation as necessary.
Don
Unread 09-01-2007, 22:34
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
low pressure tire gages are commonly available for use with racing tires, here is a sample from a large mail order hot rod parts store.
also many older automotive vacuum test gages will read pressure up to about 10 psi (for testing mechanical fuel pumps), ask around to see who on your team has a friend/relative with some automotive tools.
Unread 13-01-2007, 17:44
jesusfreakmths's Avatar
jesusfreakmths jesusfreakmths is offline
AKA: Jonathan
FRC #1778
jesusfreakmths will become famous soon enough
Send a message via AIM to jesusfreakmths
OK So what is the pressure of the Tubes? And are the tubes checked at the beginning of each game? I have been looking around and can't find any info on that. My team really needs to know because this is the deciding factor of our design.
Jonathan
Unread 13-01-2007, 19:10
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
As far as I know the PSI of the tubes will not be constant. Your robot should be able to control the tubes at a large range of PSI in the tubes. Even if the tubes become completely deflated during the game, they will still be scorable.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
How will FIRST measure muzzle velocity? ted bell Rules/Strategy 68 28-01-2006 15:44
How to measure low velocity nobtiba Electrical 28 22-04-2005 05:37
How to measure wheel revolutions Travis Covington Technical Discussion 8 24-03-2004 21:52
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
How do you measure? dez250 General Forum 14 11-01-2004 09:26
