Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 09-01-2007, 22:01
Best Available Data
FRC #1778 (Chill Out!)
Re: NASA goes metric
Originally Posted by Alex Burman View Post
http://science.slashdot.org/article..../01/09/1926236
NASA will be using the metric system on its new missions to the moon to encourage cooperation with other space agencies. Its about time, wouldn't you say Dave?
If you're referring to the whole Metric/Standard conversion incident, which resulted in the loss of a rover, it wasn't NASA's fault. It was Lockheed Martins.
Here's what Dave had to say about it.
BEAR-O-Metric karpiron Robot Showcase 0 09-02-2006 10:15
English or Metric? Jeff Rodriguez General Forum 41 19-08-2005 21:08
Going Metric Andrew General Forum 7 09-09-2003 20:51
metric gears ryan_f Technical Discussion 3 18-05-2003 11:51
English or Metric? PhillyRobotics Technical Discussion 26 30-11-2002 04:16
