Go to Post Corrected, math isn't my strong point (I went to art school for a reason) - KelliV [more]
  #31   Spotlight this post!
Unread 09-01-2007, 15:40
Choi9111's Avatar
Choi9111 Choi9111 is offline
(^_^)v I ROCK!!!!
AKA: BAKA!!!!!!!!!!!!!!!! (Tomo) >_<
FRC #0932 (Leviathan)
Team Role: Driver
Choi9111 is on a distinguished road
Re: Elevators/ Forklifts
I think that fork lifts are a great idea!...but how would it be possible to lift more than 1 robot? what do u guys think?
I AM Leviathan...only not as green and slimy...and i only have 4 limbs not 8...wait technically im not leviathan at all...>_<,
  #32   Spotlight this post!
Unread 09-01-2007, 18:22
USAF Capt. Sean's Avatar
USAF Capt. Sean USAF Capt. Sean is offline
FRC #1675
USAF Capt. Sean is an unknown quantity at this point
As for team 1675 a scissor lift is becoming a better concept. We have figured out that when it is collapsed it should take up 6"-7" inches, but once opened it could reach upto a height of 88" inches. I personally think this is HUGE payoff. We have the machines to build one and hope to be testing it soon (Within the next week or so...) But we are still talking about drive types. So it might not be done at that point.
  #33   Spotlight this post!
Unread 09-01-2007, 22:11
xur2007 xur2007 is offline
FRC #1474
xur2007 is an unknown quantity at this point
Does anyone else have quick visual aid of a forklift system?? I think i'll be making a trip to a local Home Depot get acquainted to one.
  #34   Spotlight this post!
Unread 09-01-2007, 22:13
AndrewRibeiro AndrewRibeiro is offline
FRC #1907 (Prince Edward Eagles)
AndrewRibeiro is an unknown quantity at this point
You may want to ask you school Maintenance Shop. Ours has one and let us give it a look over to help with our design.
  #35   Spotlight this post!
Unread 10-01-2007, 11:35
Jesterofkings's Avatar
Jesterofkings Jesterofkings is offline
FRC #1829 (Fire Bots)
Team Role: Driver
Jesterofkings is an unknown quantity at this point
Send a message via AIM to Jesterofkings Send a message via Yahoo to Jesterofkings
Our team come up with an to your answer your question there is 2 ways to lift 2 robots off the ground at the same time. One have a forklift on each side of ur bot and lift bots at the same team and hope they weigh the same and ur Center Of Gravity is to much to one side or the other. The other way is wat we are going to try. Have a lift strong enough to lift a bot on the front and kind of like a roll back ramp on the back. get one team to drive up on the bak and use them as a counter balance to lifting the other. The only bad things about these ideas is that you are relying on your teammates to be able to finish the round and that they will be strong enough to climb the ramps. If we figure out how to solve these problems or if u guys and gals got any ideas we will be welcome to hear them.
~Jester~
  #36   Spotlight this post!
Unread 10-01-2007, 12:01
You are making an assumption here of which you are probably unaware.
FIRST koan: Why must the two robots have the same weight?
  #37   Spotlight this post!
Unread 10-01-2007, 14:24
Scion13's Avatar
Scion13 Scion13 is offline
AKA: Steve
FRC #1727 (REX)
Scion13 is on a distinguished road
If your center of mass is outside of the wheels then gravity will apply a torque which will cause your robot to tip over
REX 1727
www.dulaneyrobotics.com
2007 Chesapeake Chairman's Award
2007 Chesapeake Safety Award
2007 New Jersey Entrepreneur Award
2006 Pittsburgh Rookie All-Star Award
2006 Pittsburgh Website Award
2006 Annapolis Best Seeded Rookie Award
Go BAA!
(Baltimore Area Alliance)
  #38   Spotlight this post!
Unread 10-01-2007, 16:42
Second FIRST koan: Does the robot tilt the Earth, or does the Earth tilt the robot?
  #39   Spotlight this post!
Unread 12-01-2007, 00:54
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Thanks for all the photos and links for the elevators!
Our team is edging closer to our decsion of whether to use an arm or elevator, but one thing that is limiting the elevator from becoming the design choice is the linear slides. Our team has found some slides, but they are too weak. We want a single tack elevator with a beefy slide that won't weaken if robot to elevator occurs by accident. We like the size of team 64's in 2005 but cannot find a slide of their size. Any help with this would be greatly appreciated.
  #40   Spotlight this post!
Unread 12-01-2007, 11:59
abroerman's Avatar
abroerman abroerman is offline
AKA: Alex Broerman
FRC #0868 (Techhounds)
Team Role: Animator
abroerman is on a distinguished road
We're at this stage as well, and as I've been home sick I figured I could try to come up with ideas of my own. The consensus is that my plan would be rather heavy, but it's possible I just embellished it too much.
Minimized (click either for a larger version)
Maximized
Anyone have more experience with extruded aluminum? How much does the stuff weigh? Would the sliders breaking be a problem? I don't know enough to make truly informed decisions regarding this plan, so I'm off to research I guess.
TechHOUNDs, team 868
-Winner of 2006 Boilermaker & Pittsburgh Regional AVA
-Winner of 2005 Rising Star Award & Boilermaker Regional AVA
check out some of my work
  #41   Spotlight this post!
Unread 12-01-2007, 19:35
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
That looks fantastic but you're right its going to be heavy. One thing to keep in mind this year is that the ringers only weigh about a pound. That device there could probably, based on my wildly inaccurate guess, support about 150 pounds just as a point of context. The first thing to do is think about your material. Aluminum square tube extrusion or 80/20 is probably a good place to start. With 80/20 you can purchase linear slides. I'm not exactly sure what they're rated for, but considering what teams have used them for in the past you can probably get away with a very lightweight design(one 80/20 strut, if properly designed).
As for the weight of a set up a good number to remember is that aluminum weighs .1 pounds per cubic inch. So a foot long piece of square aluminum tube 1" x 1" with a 1/8" wall weighs a little over half a pound. So an elevator that is 8 feet high could easily have about 20 feet of extrusion and weigh about 10 pounds but at the same time that would probably be overkill.
Team Website
  #42   Spotlight this post!
Unread 12-01-2007, 22:30
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
The discussion thus far is great, but I have two questions:
-How will these forks grab the bot to be lifted?
-What will prevent the lifted bot from falling off?
Just curious.
On another note, we are planning on using a forklift-inspired tube lifter that will grip the tubes with two sets of froks, one on top and one underneath, with each prong roughly 8" off of vertical center. We plan to be able to get two bots off the ground at the end of the match, but not by sheer force. We intend to make our lift on a pivot where it connects to the bot, and at the end of the match we will be able to rotate it downwards until it is level with the top of our bot. At this point the prongs that hold the tube will be resting on the floor to give the support for that end. A ramp will be deployed out the back, and two robots will be able to run up onto the long track resulting. We also will have a ramp out the side for that occasional bot that has a wide & short configuration rather than narrow & long as ours will be.
Any thoughts, anyone? JH
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
  #43   Spotlight this post!
Unread 13-01-2007, 00:57
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
We did elevators in 2005 using Igus drylin linear bearings.. You're welcome to come visit and we'll show you how we did it and such (we always like to talk to other teams)
here's some things I found were good and bad.
Good-
linear tracks are strong.. we cheeseholed the heck out of ours and we didnt have a problem. It did sway a little at the top but then again, we did go extremely high.
Much less programming involved, we could get the thing up and running with just dead reckon code.. good arms require good control code, dunno if thats a problem with you guys.
The things are robust.. theres not much that can go wrong with a good pulley system.
Bad-
Binding.. binding binding binding, makes it pretty hard to drag up the linear bearings (even with no load) we used 2 fisher-price motors in their plastic gearboxes attached to a spool.
Cables are annoying.. I can't stress this enough. cables have to be tensioned, there has to be a return cable.. its just annoying and unless you think it thorugh its full of surprises.
Good luck with whatever you choose
  #44   Spotlight this post!
Unread 15-01-2007, 09:27
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
Here is a basic scissor style fork lift which is quite doable.
  #45   Spotlight this post!
Unread 15-01-2007, 09:32
Molly Stieber Molly Stieber is offline
FRC #0269 (Cooney Tech Robotics)
Team Role: Electrical
Molly Stieber is an unknown quantity at this point
We have had lots of success with forklift style elevators, we used a system with cables, pulleys and bearings on our 2005 robot and it worked really well. It was pretty fast too. We have some pictures on our website, cooneyrobotics.com under the media part if you want to take a look.
pic: These elevators are fast! artdutra04 Extra Discussion 7 08-01-2007 11:09
