Go to Post Remember, GP doesnt just need to apply to FIRST; if we all apply in our lives as a whole, the world will be a better place. - Dillon Compton [more]
Unread 09-01-2007, 21:57
REVving up for a new season
FRC #2848 (All-sparks)
pic: Banebots- AndyMark crab module
Unread 09-01-2007, 21:59
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: pic: Banebots- AndyMark crab module
That design looks great. One big problem though. When you turn the wheel you motor will be beyond the limits of the robot frame. It could get damaged pretty badly or get stuck under another robot.
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 22:18
Waynep Waynep is offline
217 Alum, Former 395/348 Mentor
FRC #1923 (MidKnight Inventors)
Waynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond repute
Eugene, actually you don't. All you need for a swerve drive setup is 135 degrees of travel which can be contained within the bot. Motor reversing and programming gives you everything else.
Greg its a nice combination, but here are my concerns:
Clearance within the robot is still a problem you'd have to design for a very open robot near the pods. More importantly, the banebots motor and trans seems to be a lot of extra weight hanging off to one side to be trying to swerve. Once you are in motion its not so bad but, but you still need to have a pretty hefty motor, reduction, as well as support structure for all of this to happen.
-wayne
395 2TrainRobotics
Regional Champs- '03 VA, '05 PIT, '05 NY, '06 PIT, '06 NY; Regional Finalist- '04 NY; Engineering Inspiration- '03 NY, '06 PIT; Regional Chairman's Award- '04 NY
348 Norwell Robotics
2008 NY Regional Finalist; 2008 Curie Division Champs; 2008 World Championship Finalists
1923 MidKnight Inventors
2009 NJ Regional Champs; 2010 BOS Engineering Inspiration Award; 2011 CT Regional Champs, Gracious Professionalism Award, Coopertition Award
Unread 09-01-2007, 22:20
Billfred's Avatar
Billfred Billfred is online now
Unless, of course, you add protection through some other means.
Unread 09-01-2007, 22:37
this was only designed to go 90 degrees....because maybe that is all we wanted
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-01-2007, 22:38
eshteyn's Avatar
In that case you should have no problem with damaging it, so go for it
Unread 09-01-2007, 22:40
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
This is not a teaser, or even something that will necessarily built I just saw that with the new planetary trannies and AM kit wheels that a crab drive might be easy this year. This is by no means a module that will be build in it's present form, as it is just a quick idea.....I just wanted to share.
Please read the descriptions.
Unread 09-01-2007, 23:40
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
It would have a much smaller footprint if you put the gearbox and CIM motor above the wheel and sprocketed it down to the wheel.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 10-01-2007, 13:35
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
I'd suck it up and bevel gear it...then we'd be talkin
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-01-2007, 21:24
Skute327 Skute327 is offline
AKA: Alex Symington
FRC #0871 (Robotechs)
Skute327 has a spectacular aura aboutSkute327 has a spectacular aura about
Send a message via AIM to Skute327
I had a similar idea simply to use the motors and direct drive to the wheels. I wasn't going to pivot them. Does anyone know if the Banebots gearbox is strong enough to support a 120 # robot? (with pillow blocks of course)
pic: AndyMark booth Carol Extra Discussion 9 22-11-2006 15:44
Inexpensive crab module? Jeremiah Johnson Technical Discussion 20 24-04-2006 17:10
pic: When One BaneBots Doesn't Do team222badbrad Robot Showcase 7 07-03-2006 10:20
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
