Go to Post We have not always been a winning team but we have always tried to be a quality team. - WynS [more]
View Poll Results: Pick which in your opinion is better: Scissors Lift or DoubleJointed Arm
Scissors Lift 26 29.89%
Double Jointed Arm 61 70.11%
Voters: 87. You may not vote on this poll
Unread 09-01-2007, 22:16
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
ScissorsLift vs. DoubleJointed Arm.
What would you say the Pros and Cons are for both. Also, please vote in the poll. And can you post picture, or links to pictures of past double jointed arms or scissor lifts. Thank you.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 09-01-2007, 22:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: ScissorsLift vs. DoubleJointed Arm.
Poll?
Scissors Lift suffers fron robustness problems, kinda floppy and each joint is critical. DJ Arm is often heavier and technically more challenging, but stable, strong and potentially more robust
Don
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Both can be used for their own purposes. However i like the scissor lift better because if you build it to support all 4 corners it will be a lot more stable and safer. the most important part is to have cross bars and the joints must be made very well
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 22:21
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Scissor lifts are (typically) more difficult to manufacture, more complex, heavier, and often slower. Additionally, they cannot articulate as accurately, or create any horizontal displacement or manipulation.
Unread 09-01-2007, 22:22
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
From an engineering standpoint (even though I'm not an engineer by any means) a scissor lift is not meant to work without springs and/or pneumatics. To build a scissor lift that is robust enough to not sway would take considerable weight, and you may not have enough weight left over for a full pneumatics system. Also, I believe springs are still outlawed in the rules.
I guess this makes a double jointed arm your best choice.
Unread 09-01-2007, 22:25
It's a lot harder to build a good scissors lift than an arm. I assume the OP was talking about a device to lift tubes, right? I wouldn't use a scissors lift unless I was picking up something heavy. You could build a pretty light arm for the tubes, although it's tempting to build a heavier one that could right the robot if it tips.
Unread 09-01-2007, 22:37
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
Thank you, thats is the same points i brought up.
Unread 09-01-2007, 22:58
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Uh, neither? Our team has had bad experiences with both; a scissor lift in 2002 had trouble supporting any kind of weight at all (similarly, team 898 from next door to us tried it in 2004 and had to toss it when it couldn't support weight), and a double jointed arm in 2003 could not even support its own weight and destroyed itself (part of this was due to a miscalculation in the strain on sprockets, but regardless it still wouldn't have gone well).
We're convinced the way to go is a combination elevator/arm like we used in 2005; we've already decided we'll be doing it for this year's bot, it's just a question of exactly how they are given power to move that is up now.
Unread 09-01-2007, 23:15
Joe_Widen's Avatar
My team and I were having a debate, and for some reason there was a red flag shooting up in my mind whenever I hear scissor lift. I'm just trying to figure out what the red flag is....?
Unread 09-01-2007, 23:27
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
I believe energy storage through springs is perfectly legal, although i cant find the rule right at this moment.
Unread 09-01-2007, 23:38
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
you are right whenever I hear scissor lift i see red flags in my head, they are unstable, uncontrollable, and not durable, oh and really really heavy. There really isn't and comparison between scissor lift and a double jointed arm, a properly designed double jointed arm wins. If created properly they can be very controllable and far more flexible than a scissor lift. If you are looking for a vertical moving arm look at an forklift (elevator) type system (111 in 2005 for example). I have only ever seen one, yes one, effective scissor lift.. and too many non-effective ones.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 10-01-2007, 00:06
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
For the application of lifting a robot (or two) 12 inches, none of the sway problems stated above would really apply to the situation, and since you would only need a single joint, neither are the "every joint being critical" arguments. The single joint would allow you to Brace the lift in multiple places.(Shown by red circles in the below picture)
Now, in addition to keeping the scissor lift from swaying, the braces would also keep it from closing all the way, as is pictured below... but that is still adequate for the amount of space we have available to us.
A scissor lift could be a wonderful Idea for this years competition, It just depends which application you are using it for
For a scoring arm, however this would be an entirely different story...
Unread 10-01-2007, 00:17
Joel J's Avatar
Joel J Joel J is offline
do you..
Maybe its that the best scissor lifts (beings used as an "arm") still ends up being garbage, and is still inferior to a mediocrely designed jointed arm.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 10-01-2007, 00:42
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
These pictures are for you ... They are all "effective" scissor lifts. All that is needed to reveal a wealth of effective Ideas is a look into the past.
Some of what has been being said in this thread is nothing but a bunch of rash generalizations. If you look into Industry... you will see numerous instances of scissor lifts being used, because they are good at what they do. some mechanisms are better than others at certain tasks, It all depends on the application.
You can't just say: "Scissor lifts aren't good because they haven't been made to work yet. They will always be inferior. " It doesn't work that way.
Taken from HERE
Taken From HERE
Unread 10-01-2007, 00:45
Joe_Widen's Avatar
Yeh, the scissors lift would be primarily an arm. I think that Mr. Norris nailed it on the head. Maybe I just think that those red flags were more evident. Anyways, feel free to keep posting, I find this quite interesting.
80/20 arm Lil_moe Technical Discussion 2 05-02-2005 09:05
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
MY ARM!!! Jeff Rodriguez Chit-Chat 6 18-05-2002 20:24
