Go to Post What good will it do to have 10,000 teams who barely have a clue and are just scraping by versus 2,000 teams that are actually sustainable? - Cory [more]
Unread 09-01-2007, 22:42
DPPT1717 DPPT1717 is offline
FRC #1717
DPPT1717 is an unknown quantity at this point
Another pneumatics question
Is it legal to run a piston off a compressor without running it through a tank?
Unread 09-01-2007, 22:45
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Another pneumatics question
i dont see why not as long as you follow all regulations stated in rules <r99> to <r106>, also you really dont want to run the bimba off of just the compressor, the tank would give u fast movement for the bimba as well as repeated movement on a full tank
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 22:48
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Let's start with this: why do you want to run the piston straight off of the compressor? Maybe we can help with your implementation of the pneumatic system.
Unread 09-01-2007, 22:50
eshteyn's Avatar
He is right, we would love to help you build your system.
Unread 09-01-2007, 22:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It is legal. The minimum system is a set of gauges to show stored and working air pressure, and a relief valve to vent any stored pressure to atmosphere. You would also have to put the 60psi main regulator between the compressor and the pressure switch to turn off the compressor at 115 psi.
As eshteyn said, you'd really want a volume tank in there, though, or you'd have to wait for the compressor to fill up the piston each time you moved it. If you're worried about weight and you're only using a few small pistons, you might consider only using 4 volume tanks and keeping the compressor off your robot. You'd have a limited amount of air and number of piston firings to work with, but if you know how much you need precisely enough, you could make it work.
Unread 09-01-2007, 23:09
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Shouldn't the pressure switch be before the regulator, in other words "put the pressure switch between the compressor and the regulator to cut the compressor off"
Brian
Unread 10-01-2007, 00:04
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
At the very least, I would reccommend using one tank. It isn't going to add THAT much weight (as much as, say .. 4 tanks), and your cylinder movement is going to be much smoother.
As for 4 tanks vs the compressor, I would take the compressor and one tank. Depending on the application of course. If you're using this just to shift a pair of transmissions with a .75" bore 1" stroke piston .. then go with the tanks. If you're moving a 1.5" bore 18" stroke piston on an arm .. then maybe you should consider the compressor.
And the pressure switch needs to go before the main regulator. If it wasn't, you'd never get past 60psi, and the compressor would run until the relief blew. Not smart.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 10-01-2007, 01:29
Joobacca Joobacca is offline
FRC #0192
Joobacca will become famous soon enoughJoobacca will become famous soon enough
it is not to your advantage to not use a reservoir coming from your compressor. it allows for more pressure to be store before going out to your actuators and stores air in the system for when you aren't using the pneumatics. it's sort of standard to use tanks. you're thinking though!
Unread 11-01-2007, 23:38
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
There's another reason to use as many tanks as is allowed: You can precharge the tanks before the round.
Consider: The total amount of work (in the physics sense) allowed in a FIRST pneumatics system equals (A) whatever you can compress during the round, PLUS (B) whatever energy was stored in the tanks before the round.
Therefore, to maximize this value you want to go into the round with the largest storage volume allowed, prefilled with compressed air stored at the maximum PSI allowed!
Now OTOH, the compressor, its spike, the control hardware (et al) all cost you in weight. Therefore, IF you are using only a tiny amount of air during the round (such as the only pneumatic device is your "end of round release trigger widget", or "pneumatic gear shifting" with tiny cylinders and little work will be done), then by all means delete the compressor and drive the pneumatic load with just the storage tanks precharged to their max pressure.
A few caveats though:
1) All FIRST supplied valves are 'piloted'. They use air to either maintain their state (every 'spring return type' of valve in the kit), or require a minimum pressure to exist to switch state (such as the SMC dual coil type valve).
Example - Try this out: Build up the compressor component. Attach the "grey" (Festo) valve as directed with any cylinder as a "load". Turn it on by putting 12VDC onto its contacts. NOW, slowly reduce the input air regulator's setting... You'll quickly discover that although the coil to the valve is still "on", once the pressure drops low enough (somewhere in the 20-35 PSI range) it WILL suddenly switch to the "off" state! The spring return "becomes stronger" than the "hold" pressure, and it switches off although the light is still on! With the dual coil SMC valves, you may find that you can no longer switch state once the tank pressure has dropped too far.
(I do this demo with every incoming rookie class to our team, to impress upon them the need to tinker and try things out, as some devices in the kit may not act as you think!)
FYI, if you check the specs, most of the valves in this contest state they they need somewhere around 35 PSI minimum input pressure to operate. So, if you're contemplating a "tank only" system, your total consumption should never allow the tank pressure to drop below that value at any time during the round, or else unpredictable behavior may occur.
2) Avoid using the vaccum generator with a tank-only system! The unit continuously consumes air to generate and maintain vacuum. That means you'll only have a VERY limited number of "grip-on" seconds in total. (I think it would be mighty embarassing to drop your Ringer while you're still jockeying for position, and not be able to pick it up again!)
3) To maximize total actuations possible, minimize the total cylinder volume of your loads, by picking the absolute minimum bore and stroke required to get the job done. After all, every time you actuate a cylinder (in either direction), you "throw away" it's total displacement volume of air. In an air-limited application, that could become important.
I hope this helps!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Another CIM Question Carlo Motors 4 14-02-2005 22:02
Ok another question Rhs953 Motors 2 30-01-2004 23:05
Another Question. Jacob Morgan Electrical 6 05-01-2004 18:32
Another field question. archiver 2001 0 23-06-2002 23:41
Pneumatics Question archiver 2000 1 23-06-2002 22:46
