Go to Post WE DEMAND FREE CORNDOGS FOR ALL MENTORS UPON ENTRY INTO THE EDWARD JONES DOME. #yourmovefrank - Jared Russell [more]
Unread 09-01-2007, 23:09
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Crab drive without a pot
I was wondering if it would be possible to do a crab drive without using a pot to figure out what angle the wheel is it and if it is how difficult the programming would be. Thanks in advanced
Unread 09-01-2007, 23:10
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Crab drive without a pot
Trust me, you really want to put in a pot, it will only make your life easier during programming and then you can put wheels inexact positions and the robot will do exactly what u want it to do
Championship - Delphi "Driving Tomorrows Technology"
Unread 09-01-2007, 23:11
dpick1055's Avatar
David Pick
How expensive would a pot be and where could we get them?
Unread 09-01-2007, 23:14
eshteyn's Avatar
it would be about 2 dollars and 50 cents from radio shack
http://www.radioshack.com/search/ind...otenti ometer
but if you want it in large quantities u can get it cheaper at
www.digikey.com
Unread 09-01-2007, 23:15
eshteyn's Avatar
get the linear-taper-potentiometer
Unread 09-01-2007, 23:16
dpick1055's Avatar
David Pick
Thanks.
Unread 09-01-2007, 23:22
eshteyn's Avatar
anytime
Unread 14-01-2007, 00:46
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
I have a question about using pots on crab drives.
It seems to me like you could have a 359 degree rotation using a pot, but then to go from, say, rightish forward to leftish forward wouldnt you need to rotate the wheel all the way around the long way? Assuming 0 on the pot is straight ahead.
Are there pots that give you a range of values up to one turn and if you turn past that they would reset?
We were considering using encoders on these shafts... but I'm not the best programmer in the world
Any advice is greatly appreciated.
Thank you,
Dave
Unread 14-01-2007, 01:07
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
You can buy pots that are set to a different amount of rotations, or you could use (like you suggested) shaft encoders.
Unread 14-01-2007, 01:45
AdamHeard's Avatar
Lead Mentor
You could also use endless pots, it would be slightly harder to program than normal (you have to anticipate the "wrap around", still not to hard though) and you still get endless rotation as you desire.
Unread 14-01-2007, 09:59
Dave Scheck's Avatar
Dave Scheck Dave Scheck is online now
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I would highly recommend not using encoders to determine crab position. Yes they can work, but they require you to precisely position the wheel at startup. Since the encoder doesn't tell you where you are, you could have the wheel turned 90 degrees and the RC has no way of knowing that it's not centered. Pots are far superior in this aspect because they give you an absolute position at startup and the necessary corrections can be made.
Unread 14-01-2007, 14:52
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
True, but normal potentiometers have the nasty disadvantage of having a hard stop. When we did swerve drive in 2004, we broke a lot of potentiometers (especially in testing) by turning them too far. In hindsight, it might have been a better idea to use encoders, set the wheel to a known position at the start of the match, and probably have a limit switch as a backup that would be triggered (e.g.) when the wheel was straight ahead - so if anything happened, you could have a reset button that would spin the wheel until it triggered the limit switch and then would reset the encoder count. (You could also do this on the fly - every time that switch happens to be triggered, have an interrupt that corrects the encoder count.)
Unread 14-01-2007, 15:06
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
A couple of years ago our crazy electrical guy made a full rotation potentiometer by cracking it open and cutting off the stop. (Not recommended, you can screw things up by putting voltage across a shorted potentiometer)
There are ways to use optical sensors to encode position rather than motion.
http://http://en.wikipedia.org/wiki/Gray_code
Unread 14-01-2007, 16:42
Bharat Nain's Avatar
Did you try using a 10-turn pot?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 14-01-2007, 17:56
FRC #3683
We had 5-turn pots, so 2.5 turns in either direction. 10 turns might have been better, but I still think we would have broken a few (and, of course, we would have had lower resolution - but I'm not sure that would have been significant).
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
EduRobot Crab Drive OneAngryDaisy Robotics Education and Curriculum 8 03-10-2003 10:06
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
