Re: Belt Configuration
Thanks, but putting an idler on the other end might not be feasible because the belt we have is custom made to length. slippage is minimal due to the teeth in the belt meshing with the teeth in the wheels. Our previous configuration had less contact with the wheels. thanks again for your input
| Configuration File? | FFnut | Programming | 2 | 03-02-2006 17:38 |
| Check All option on Recent Activity Configuration | sanddrag | CD Forum Support | 0 | 29-01-2006 22:35 |
| Victors, Default code, & joystick configuration | Vermatitis | Electrical | 4 | 27-01-2005 16:01 |
| R06 - weight and configuration | jimfortytwo | Technical Discussion | 6 | 18-02-2004 08:06 |
| Possible Configuration to keep things cheap | archiver | 1999 | 8 | 23-06-2002 23:03 |
