Re: Funny Video: Use of pump
I don't think this set up would be allowed in competition since it wouldn't be at 60psi. We set up the vacuum and it is powerful but it pretty much requires the compressor to be running constantly. It doesn't always pick rings up on the seams. Also keep in mind that while it is very strong, the suction is broken if you touch the area near it. This might be a problem if a defending robots hits the tube or if you miss align and hit part of the spider legs.
hahah wow it is strong were still on our mock up phase and havent tinkered with any parts yet but haha vid 2 was funny
Are all the parts needed to rig this up in the KOP?
Yes. You have a venturi pump, a suction cup, 4 mm tubing, a compressor, 2 clippard tanks, all the pneumatic gauges and regulators and switches, and the fittings for the 4 mm tubes and the suction cup.
2 points of contact should significantly help with rotating.
The optimal pressure according to the piab site is 26 psig. This is well under the 60 psig max. The limit of 4 clippard tanks (at 120 psig) should be able to sufficiently power the vacuum device. Higher pressures are actually detrimental to the suction and it relies mostly on the air speed through the venturi type nozzle. If a constant running compressor (vacuum generators can be air intensive) are a concern, vacuums can be constucted with KOP motors (which in a vacuum actually draw less amps). |
| Team 1511 video "learning how to use a alenwrench" | Mirza95vx | Robot Showcase | 2 | 05-02-2005 17:36 |
| Video Editing Programs...share what you use and why... | Alexander McGee | 3D Animation and Competition | 25 | 09-01-2003 22:27 |
| Pump | RobDeCotiis | Pneumatics | 12 | 01-11-2002 21:31 |
| Insulin Pump | Melissa Nute | Chit-Chat | 2 | 17-10-2002 18:19 |
| Pump Problems... | archiver | 2001 | 2 | 23-06-2002 23:58 |
