Go to Post I shouldn't be doing a happy dance or anything, should I? - Qbranch [more]
Unread 01-09-2007, 10:37 PM
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
<R12> 72" x 72" Size Restriction
Outside the home zone the robot can expand to max of 72"l x 72"w and unlimited height. Do you think 72" this includes temporary expansion like and arm?
Where the arm might stick 4 or 5 feet outside the robot to place the top tube?
Unread 01-09-2007, 10:40 PM
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: <R12>
Im not exactly sure i believe it does include it, but i would e-mail first and as for sure, if you find out please share.
Championship - Delphi "Driving Tomorrows Technology"
Unread 01-09-2007, 10:45 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: <R12>
It almost certainly means anything for any amount of time. What should really get you thinking is if it only means you should be able to fit your robot inside a 72" x 72" area at all times, or if there are some sort of defined x-y axes on your robot that fix the orientation of the square.
That is to say, if you only have a pole sticking out the front of your robot, can you assume the pole is extended along a diagonal of that square and is limited to something like 90"? Or do the edges of the square have to be parallel to the sides of your robot and you're limited to 72"?
Unread 01-09-2007, 11:33 PM
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
Re: <R12>
Does this also apply for the endgame?
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Unread 01-09-2007, 11:44 PM
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: <R12>
It doesn't apply if you're in the home zone. You can have a length as wide as the playing feild as long as you stay inside the playing feild.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 01-10-2007, 01:17 AM
Joobacca Joobacca is offline
FRC #0192
Joobacca will become famous soon enoughJoobacca will become famous soon enough
Re: <R12>
You DO realize that 72 inches is equivalent to 6 feet. Does that answer your question?
Unread 01-10-2007, 06:03 AM
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Re: <R12>
But the question was "Where the arm might stick 4 or 5 feet outside the robot to place the top tube?"
38 inch robot plus 60 inch arm equals 98 inches which is more than 72 inches.
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 01-10-2007, 07:07 AM
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: <R12>
Last year you could not extend higher than 5'. If you had a 4' 6" bot that had a door on top that was 1' long and it rotated past the 5' limit when opening you would be penalized.
This year I see a 72" L x 72" W x infinite high box and if you extend out of this box you will be penalized. Even if it's only for a moment.
Just my $.02 YMMV
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 01-10-2007, 08:47 AM
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: <R12>
R12 is very clear. They define a "Box" 72"x72" of which the diagonal is more than 101"
But, if the arm swings out of the box, you risk being panelized. I don't know if this will be an inspection item this year. The sizing is already complicated with the different classes. The Refs may have a way of measuring on the field.
Try designing a round robot using omni wheels. It will be very hard to define the width and depth axis.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 01-10-2007, 09:36 AM
Kingofl337's Avatar
AKA: Adam
Re: <R12>
I guess the big problem is with and arm while its lifting a ringer from the ground robot will normaly break that 72" plane for a brief amount of time and then return to within the 72" rule. To stay within the rule your arm would have to retract the arm back in towards the robot before extending out again. I think the intention of the rule is to stop huge robots roaming around the field and not to limit arm design. But, thats question I'm trying to find out.
Unread 01-10-2007, 09:54 AM
Brandon Holley's Avatar
Re: <R12>
I honestly cannot wait to see the refs out there with tape measures trying to see what the invisble 72" box is, and when a robot extends out of it. Honestly this seems quite difficult to enforce if what were talking about is the correct interpretation.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 01-10-2007, 10:05 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: <R12>
If the arm is built so that it's pivoting mount is at one end of the robot, and the arm is less than 72" long fully extended, you'll be ok. Consider making the arm so that it only can pivot up and down, it cannot swing sideways (or not very far sideways). A 66" long (total extended length) arm/hand mounted on a 56" high mast at the "back" of a robot, would be able to reach the floor and also score high ringers, I think. Make some sketches, see how the geometry works. There seems to me to be no need to make the robot extend further than 72" in length/width to perform it's task.
Unread 01-10-2007, 10:12 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: <R12>
I can seen Robot Inspectors doing exactly that, before your robot ever gets to the field. An extra long arm is a potential safety hazard to people near the field boundary, such as referees, emcees, announcers, field resetters, etc. To protect those people, the Lead Robot Inspector has discretion under <R112> to keep any robot off the field, even for practice, until it has been brought into compliance with the rules.
Richard Wallace
since 2003
Unread 01-10-2007, 10:51 AM
Re: <R12>
I also can see this, but there are many different orientations of robots. This also severely limits the types of arms you can make, articulation will require some thorough calculations.
Unread 01-10-2007, 10:59 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: <R12>
The rules are simple. Your robot may, during normal play, not exceed 72" X 72". Use your GP, stay within the confines of the rules, don't try to bend or break these rules and everything will be fine. Yes, some rules make the game hard - that's the point! With each limitation comes a new challenge, another opportunity to show off your team's ingenuity.
Personally, I would hope that refs would never have to whip out their 72-inch measuring sticks - if the robots are designed respectfully within the given boundaries, there won't be any problems.
Hi!
Is there a restriction to what sensors we can use? Robot Dude 0101 Kit & Additional Hardware 28 01-11-2005 10:43 PM
height restriction on pits nzj1 General Forum 10 01-09-2005 09:34 PM
size limitations D: Kevin Karan Programming 6 03-20-2004 09:20 PM
size great_one411 General Forum 3 02-06-2003 09:02 AM
Ball size? archiver 2000 8 06-23-2002 10:24 PM
