Go to Post oh, the prom! I thought you were missing a PROM (Programable Read Only Memory) ...you had me worried for a minute, I dont know if IFI has any spare PROMs. - KenWittlief [more]
Unread 10-01-2007, 01:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Magnets and reed switches (what's an AT?)
See the chart on the second page of this:
http://www.cotorelay.com/RI-01B_Series.pdf
Can somebody tell me what the unit AT is? Amp-tesla? Google doesn't seem to recognize that phrase, and it sounds a little funny anyway. Judging from the way that it's being used, it seems like some unit of magnetic force or field strength. How does this translate into some function of the strength of a magnet and the distance away? I'm interested in using a permanent magnet, but I suspect that AT has something to do with coils.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 10-01-2007, 02:01
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Magnets and reed switches (what's an AT?)
Don't really know what it is either, but your coil theory would go best with AT for Ampere-Turn according to Wikipedia.
http://en.wikipedia.org/wiki/Ampere-turn
Honestly, I'm no electrical engineer, but maybe someone out there is an engineer.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 10-01-2007, 08:28
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Ampere Turn. Coto's application guide http://www.cotorelay.com/Reed_Relays...n_-_Entire.pdf covers a fair amount of information that you might find helpful.
The application guide for the reed switches themselves is here: http://www.cotorelay.com/Reed_Switch...n_-_Entire.pdf
These documents, and others, can be found under the 'Literature' section of their website.
From that, you should be able to correlate a coil's AT field with the measured magnetic strength of your magnet.
When working with a switch like this, be aware of things like contact bounce when writing software that takes actions on the switch action.
While not as much of an issue with small reed switches, many switches and relays will have a minimum contact current specification. Commonly referred to as the "wetting current", it is the minimum current required to flow through the contact to prevent oxidation buildup from creating a high impedance path.
--Dave
Unread 10-01-2007, 11:17
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
On the odd chance that anybody else should ever have the same question, one of the documents that Dave linked to has a graph that indicates that an ampere-turn with a Philips Standard Coil is equivalent to about 0.44 gauss for a permanent magnet. Thank you to Gabe and Dave for their help.
_
Magnetic Reed Switches and cylinder boom positions???? cdennisxlx2 Pneumatics 7 11-07-2006 21:17
Magnetic Reed Switches (need help) cdennisxlx2 Pneumatics 1 03-02-2006 06:47
I need help with the reed switches!!!!!!! archiver 2001 2 24-06-2002 00:40
Optical Sensors and/Or Magnets archiver 2000 3 23-06-2002 23:01
Reed switches archiver 2000 4 23-06-2002 22:08
